Energy from cosmic microwave background
The cosmic microwave background (CMB) energy density is measured at 4.005 x 10-14 J/m3. Calculating the energy received by Earth involves using the Earth's surface area of approximately 1.28 x 1014 m2 and the speed of light at 300,000 m/s. This results in an estimated power of 1.53 x 106 Joules per second from the CMB. Additionally, applying the Stefan-Boltzmann law indicates that the Earth emits approximately 1.6 Gigawatts of energy back into space, significantly exceeding the energy received from the CMB.
  • Understanding of cosmic microwave background (CMB) radiation
  • Familiarity with the Stefan-Boltzmann law
  • Basic knowledge of energy density calculations
  • Proficiency in unit conversions and scientific notation
  • Research the Stefan-Boltzmann law and its applications in astrophysics
  • Explore the implications of cosmic microwave background radiation on cosmology
  • Learn about the methods for measuring cosmic background radiation
  • Investigate the relationship between temperature and energy emission in black body radiation
Astronomers, physicists, and students interested in cosmology and the properties of cosmic microwave background radiation will benefit from this discussion.
chris1969
Hello everyone
I've a question about the cosmic microwave background which my nephew asked me a couple of days ago. How much energy hits the Earth each year from the CMB? I'm assuming here that it is measurable in this way, but apologies if not.
Thanks in advance for your help.
Chris
Science news on Phys.org
On Wikipedia, I found this number for the intensity of the CMB. ##4.005 x 10^{-14} \frac{J}{m^3}##
Now, can you look up the Earth's surface area and do the rest of the math?
Unfortunately you indicated a volumetric density. I think the number is reasonable though as https://dspace.carthage.edu/bitstream/handle/123456789/37/Adam%20Ferg.pdf?sequence=1 states ~10^-14 W/m^2.
Easy enough to fix - multiply by the speed of light.
Not that easy, the direction is random. There is another factor of order one.
Thanks ever so much everyone. Can I check my logic/arithmetic please?
1) Energy density of CMB is 4.005 * 10^-14 (Joules per cube metre)
2) Radius of Earth is about 6,371 km
3) Surface area of Earth is about 1.28 * 10^14 metres squared
4) Speed of light is 300,000 m/s
Multiplying (1) * (3) * (4) would give about 1.53 * 10^6 Joules per second from the CMB.
Am I on the right lines here, or have I made a basic error somewhere.
Thanks once again. It's been over 20 years since I did high school physics, so I more than a little rusty.
Chris
I would go with Stefan-Boltzmann and use the surface area of the Earth as the surface area of the black body that is shining on us - in which case you get a power of:
Area_of_Earth x Sigma x T^4 = (5.10*10^14) * (5.67*10^-8) * (2.726^4) = 1.6 Gigawatts
In case your cousin wonders whether the sea will eventually boil from all that energy hitting the earth, you might care to point out that the Earth (being at say 300°K) is shining back into space of order 100 million times what it is receiving from the CMB (being at 2.7°K). ((300/2.7)^4 from Stefan-Boltzmann law)
  • · Replies 39 ·
  • · Replies 20 ·
  • · Replies 29 ·
