Energy needed to raise an object to a certain altitude
The discussion centers around the energy required to raise an object to a certain altitude, examining the implications of the law of conservation of energy in this context. Participants explore the mechanics of energy transfer when using a helium balloon to lift an object and the subsequent energy dynamics when the object is released and falls.
  • Some participants propose that the energy needed to raise an object must equal or exceed the energy released when the object falls, due to conservation of energy principles.
  • There is a discussion about the role of the atmosphere in energy transfer when a helium balloon lifts an object, with some suggesting that the air loses potential energy as the balloon rises.
  • Questions are raised about the mechanism of energy transfer, with one participant suggesting that denser air fills the void left by the rising balloon, contributing to potential energy changes.
  • Participants explore the implications of releasing the object from the balloon, questioning where the impact energy comes from and how it relates to the energy used to fill the balloon with helium.
  • Some argue that the change in potential energy of the atmosphere is greater than that of the object being lifted, indicating a complex interaction between the lifted object and the surrounding air.
  • There is mention of Archimedes' principle and its relevance to buoyancy, with some participants discussing the differences in energy dissipation between balloons with and without additional weight.
Participants express varying views on the mechanisms of energy transfer and the implications of buoyancy, indicating that multiple competing perspectives remain. The discussion does not reach a consensus on the specifics of energy dynamics involved.
Some limitations include assumptions about the energy dynamics of helium extraction and the specific conditions under which the energy transfer occurs. The discussion also reflects uncertainty about the overall energy balance in the scenarios presented.
Warp
My thinking is that because of the law of conservation of energy, the amount of energy needed to raise an object to a certain altitude has to be at least as much as the amount of energy released by the object if it were to be dropped from that altitude and hit the ground (and all that released energy gathered somehow). I'm thinking that it has to be at least that much because if you needed to spend less energy raising the object than it releases when it falls, you could use part of the released energy to raise it again, and get the remaining energy from nothing (which is impossible).
But then I got thinking: If you used a helium balloon to raise said object, what exactly is expending the energy to raise the object? Where is that energy coming from? What is it away from? What loses that amount of energy in order to have the object raised to that altitude, transferring it that much potential energy?
The air in the atmosphere.
So... how does this manifest, exactly? Does the air get colder or something? What's the mechanism of energy transferral?
When the balloon goes up, a more dense part of the atmosphere comes down to fill the void left by the balloon. That falling atmosphere provides PE to the object being raised.
Do I understand correctly that the air loses some potential energy and the arising balloon+object gains it?
But now, if the object (let's say it's a metallic ball) is let loose from the balloon, it will fall down and release energy when it impacts the ground. In the atmosphere, however, not much has changed. Where did that impact energy come from?
Is this, like, some kind of rather convoluted way of transferring the energy used to fill up the balloon with helium to the object, or something along those lines?
Yes. The bulk of the atmosphere is lowered as it lifts the balloon + object + helium.
The change in potential energy of the atmospher is greater than the change in potential energy of the ball alone.
Realize that it takes a pretty large balloon to lift a pretty heavy ball. The weight of the displaced air is equal to the weight of the helium + balloon + metallic ball that was lifted by atmospheric buoyancy.
Think about continuing the scenario. If you try to pull the inflated balloon back down, you will have to supply energy. That energy can be thought of as lifting the atmosphere back up to make room for the inflated balloon.
From the work done by the atmosphere to lift it, as described above.
That would depend on where the helium came from in the first place. Google tells me much of it is separated from natural gas, which comes out of the ground pressurized. There's a lot of potential energy in the pressure and buoyancy, but I don't know if it is more than the energy needed to separate it from the natural gas or who's ledger sheet that energy is recorded on (the helium or natural gas's).
Are you familiar with Archimedes' principle?
https://en.wikipedia.org/wiki/Archimedes'_principle
Whatever was lifted up by buoyancy weighted less than the air that went down to fill its place. So the atmosphere always looses more potential energy than the floating up objects. That is where their energy comes from.
Note that if you use balloons of the same volume with and without the metal ball:
- The balloon without the ball will raise faster and dissipate more energy through drag.
- The balloon with the ball will instead put that energy into the potential energy of the dumped ball, which is dissipated on ground impact.
So there is a difference in the atmosphere between the two cases.
  • · Replies 24 ·
  • · Replies 55 ·
  • · Replies 16 ·
  • · Replies 41 ·
