How Does Energy Convergence Relate to Fourier Series Representation?
The discussion focuses on understanding the relationship between energy in a function and its Fourier series representation, specifically using the example function y = 3t. The Fourier representation yields a DC average of 3π, with sine terms but no cosine terms, and the energy is calculated using Parseval's theorem. After applying 13 harmonics, 99% of the original function's energy is captured, but the user seeks clarity on determining the limiting value for convergence. They express uncertainty about whether this limiting value exists and if the energy difference would be zero at that point. The inquiry emphasizes the broader concept of convergence in infinite series, rather than just Fourier series.
Jag1972
I have been trying to understand the Fourier series and the relationship between the energy in the original function and its Fourier representation. The example function: y = 3t has a period of 2∏. The Fourier coefficients are:
The Fourier representation has a dc average of 3∏, it has no cosine terms but does have sine terms with amplitude equal to -6/n.
Using Persavals thereom I can determine the energy in the Fourier series:
\frac{1}{\pi}\int^{2\pi}_{0} 3t^{2} dt = a0/2^{2} + \sum bn^{n}
After using about 13 harmonics I got it to 99% of the energy of the original function. I do not know how to get to a limiting value which I think is called convergence. A stable value reached, if there is no stable value then the function diverges. I know there are tests for convergence and divergence but these will not give actual limiting values. My question is that how does one know what the actual limiting value is orthis just something we have to reach ourselves, also would the energy difference be 0 at this limiting value. I hope it will be.
Thanks in advance.
Mathematics news on Phys.org
That is not an electrical for Fourier question. You are asking about convergence of any infinite series.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
