Energy-Time Uncertainty of Gaussian
The discussion focuses on verifying the energy-time uncertainty principle using a specific wavefunction, \Psi(x,0)=Ae^{-ax^2}e^{ilx}. Participants explore the calculation of the expectation values <H> and <H^2>, with some suggesting that these values may not change over time and can be derived from the initial wavefunction. The complexity of the resulting expressions is acknowledged, with one participant providing a method to simplify the calculations by completing the square in the Gaussian. Additionally, there is a debate about the role of the function phi(k) in relation to energy eigenfunctions and its significance in the overall problem. The conversation emphasizes the mathematical nature of the problem, noting that it may not enhance physical intuition but serves to reinforce computational skills in quantum mechanics.
sspitz
Check the energy-time uncertainty principle for:
using the observable x.
<br /> \Delta{E}\Delta{t}\geq\hbar/2\\<br /> \Delta{E}=\sigma_H=\sqrt{&lt;H^2&gt;-&lt;H&gt;^2}\\<br /> \Delta{t}=\frac{\sigma_x}{\frac{d&lt;x&gt;}{dt}}<br />
First I find the wavefunction with time dependence
<br /> \Psi(x,t)=\frac{1}{\sqrt{2\pi}}\int{\phi(k)e^{ikx-i\frac{\hbar k^{2}t}{2m}}dk}\\<br /> \phi(k)=\frac{1}{\sqrt{2\pi}}\int{\Psi(x,0)e^{-ikx}dx}<br />
This gives me a fairly complicated expression
<br /> \Psi(x,t)=\frac{Aexp(\frac{-ax^{2}+lix-\frac{tl^{2}i\hbar}{2m}}{w^{2}})}{w}\\<br /> A^{2}=\sqrt{\frac{2a}{\pi}},w^{2}=1+\frac{\hbar2ita}{m}<br />
Just finding <H> (not to mention <H^2> is giving me a lot of trouble. Is grinding out the derivatives and integrals the only way to do this problem?
The only other options I can think of:
1: <H> and <H^2> should not change in time (?), so I can just use the wavefunction at t=0 to find them? (But, still have to use the wavefunction with time to get the std dev of x)
2: Considering \frac{e^{ikx}}{\sqrt{2\pi}} are like orthonormal eigenfunctions for H, could I say:
<br /> &lt;H&gt;=\int{\phi(k)^{2}E(k)dk}<br />
remember that
\Psi (x, t) = e^{(-i/ \hbar) H t} \Psi (x, 0)
H commutes past the time evolution operator
x does not, use a series expansion to determine the correct commutation relation
Furthermore complete the square in the gaussian
You are definitely on the right track. Your expression is going to be ugly. Now, set
z\equiv 2 \hbar at/m
and use
\lvert \psi \lvert^2= \sqrt{ \frac{2a}{ \pi}} \frac{1}{ \sqrt{1+ z^2}} e^{-l^2/2a}e^{a\big\{ \frac{(ix+l/2a)^2}{(l+iz)}+ \frac{(-ix +l/2a)^2}{(1-iz)}\big\}}
Expand the term in the brackets {} of the right-hand exponent, and plug it back into
\lvert \psi(x,t) \lvert^2
where your psi should be
\psi(x,t)= \bigg( \frac{2a}{ \pi}\bigg)^{1/4} \frac{1}{ \sqrt{1+2i \hbar at/m}} e^{-l^2/4a}e^{a(ix+l/2a)^2/(1+2ia \hbar t/m)}
Thanks for the help. I think I got it.
As a check on comprehension, I'd be interested in knowing if #2 in the original post is right or wrong and why. It seems to me that phi(k) above is for energy eigenfunctions what the momentum space wavefunction is for momentum eigenfunctions. That is, roughly, both show the amount of each eigenfunction in psi.
Code:
Sorry, I misunderstood your last question, so I'm editing my post. I'm going to have to come back to your #2 point later, since it's getting late where I am. The following was written when I misunderstood your question, so I'm just going to post it rather than waste it. If we're being honest, this problem is designed just to make you do some math. It doesn't really help you with any physical intuition. By convention, the time evolution operator is
\hat U (t,t_0) = e^{-i(t-t_0) \, \hat H/ \hbar}
or in application,
\big\lvert \, \psi(t) \big&gt;= e^{-i(t-t_0) \, \hat H/ \hbar} \big\lvert \, \psi(t_0) \big&gt;
So, for example, if you've got an infinite square well, at t_0 =0, in its ground state,
\big\lvert \, \psi_{n=1} (t=0) \big&gt;= \big\lvert \, \psi_1 (0) \big&gt;= \sqrt{ \frac{2}{a}} \sin\frac{ \pi x}{a}
You know the energy is
E_1= \frac{ \hbar^2 \pi^2}{2ma^2}
So at a future time t,
\big\lvert \, \psi_1 (t) \big&gt;= e^{-it \, \hat H/ \hbar} \bigg(\sqrt{ \frac{2}{a}} \sin\frac{ \pi x}{a}\bigg) = \bigg(\sqrt{ \frac{2}{a}} \sin\frac{ \pi x}{a}\bigg)e^{-it \, E_1/ \hbar} =\sqrt{ \frac{2}{a}} \sin\frac{ \pi x}{a}e^{-it \, \hbar \pi^2/2m a^2}
Time evolution is really pretty simple. It gets convoluted with Green's functions and stuff like that, but really for all intents and purposes, you should just think of it as in the example above.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
