English Naming Guide for Physics Variables in Flash Programming
The discussion focuses on terminology related to Rigid Body Dynamics in programming. Key terms include the spring constant, also known as spring rate or stiffness, which describes the force a spring applies. The damping factor, calculated by the speed of compression, is referred to as the damping constant. The relaxed length of a spring can be called either the original length or unloaded length, with caution advised regarding pre-load and post-load distinctions. The user also mentions naming their force accumulation and velocity change functions as force() and step().
Alphanimal
Hi there!
I'm not english, and i learned Physics in German, so i don't know how certain things are called.
I am programming a Rigid Body Dynamics Engine for Macromedia Flash, and I'm often not sure how to name my variables.
Well, how are the following things called in english?
1. The constant factor a spring has, which describes the force it applys (force = (relaxedLength-currentLength)*someFactor)
2. When a spring is compressed/extended, it can have some kind of damping or cushion. (It is calculated by the speed at which the spring is compressed) How would you call this factor (dampForce = compressionSpeed*strangeFactor)
3. Another factor, that decreases speed continously. (every time unit the speed is multiplied my a value between 0 and 1, it has some kind of air-friction effect, causing speed to move against 0)
4. in dynamics programming, first every force is accumulated, and then these forces are integrated (the moment of kinematics) how would you call the step of accumulating Forces, and the Step of making these forces change velocities?
5. The relaxed length of a spring ("relaxed" or "unstressed", ...)
Of what expressions can you think?
Thanks very much!
This is called the spring constant, spring rate, or occasionally stiffness (not to be confused with the material stiffness). Usually the letter 'k'.
The damping constant. Usually the letter c.
I'll probably make a hashed attempt at 3 and 4, so I'll leave those out!
Either of those will do. I tend to use original length, but you could use unloaded or relaxed. Be careful to distinguish between pre-load and post-load lengths, if the spring is permanently deformed by your load.
Wow thanks very much :) fast answer!
4.: I named them force() and step() for now...
maybe you want to take a look where i am learning dynamics for the engine: http://www.d6.com/users/checker/dynamics.htm
i do not really understand everything (difficult english) but the 2 steps are described there
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
