Entanglement and FTL signaling in professional scientific literature
The discussion centers on the implications of quantum entanglement regarding faster-than-light (FTL) signaling, exploring the relationship between quantum physics and relativity. Participants examine whether entanglement allows for any form of FTL communication or influences, and the theoretical frameworks that support or contradict these ideas.
  • Some participants assert that relativistic local quantum field theory (QFT) prohibits FTL causal actions by its foundational assumptions, which include the commutation of local observables at space-like separations.
  • Others question whether there are theories that do not take the speed of light as an axiom, particularly in non-relativistic QFT, where the framework does not impose such limits on speed.
  • It is noted that non-relativistic QFT lacks the structure to define time-like, light-like, and space-like vectors, leading to different implications for causal signal propagation.
  • Some participants differentiate between FTL signaling and FTL influences, suggesting that while entanglement does not permit FTL signaling, it may allow for influences that occur instantaneously.
  • A participant raises the concern that defining signaling in terms of complex systems may overlook other potential forms of communication or influence that could be interpreted as signaling.
  • There is a discussion about the implications of experimental observations on the nature of spacetime, with some arguing that current evidence supports a Lorentzian framework with light speed as the maximum invariant speed.
Participants express differing views on the relationship between entanglement and FTL signaling, with no consensus reached. Some agree on the prohibition of FTL signaling based on established theories, while others propose alternative interpretations and challenge the definitions of signaling and influence.
The discussion highlights the complexity of defining signaling versus influence in the context of quantum mechanics and relativity, as well as the limitations of current theories in addressing these concepts. There is also an acknowledgment of the need for further exploration of alternative frameworks beyond established principles.
  • #241
DrChinese said:
@Morbert:
a. I agree, Bob would then see a 50% "up" rate rather than 100% assuming Alice's results are unknown. If measured at different angles (but Alice IS known), the results follow the usual expectation value. @PeterDonis:
b. My statements ("Either Alice's measurement casts Bob's particle into a state synchronized with Alice, or Bob's measurement casts Alice's particle into a state synchronized with Bob.") ARE symmetric (or commute), and precisely fit the facts. There are no other facts you can state about the results OTHER than what I say.
But it contradicts the very foundation of relativistic QFT, i.e., the microcausality constraint on local observables, i.e., there cannot be a mutual influence of A's and B's measurements if the "measurement events" (photon-detection events) are space-like separated.
DrChinese said:
c. The entangled state absolutely does NOT predetermine the outcomes of (all possible) measurement choices by Alice and Bob. Bell ruled that out for all possible type of hidden variables (see d. below for quotes). The best you could say is that it is responsible for the random element to the outcomes, which are otherwise unaccounted for in the quantum expectation value for matches.
Of course the entangled state doesn't predetermine any of the outcomes of the possible single-photon measurements, because the single-particle states are maximum-entropy mixed states, i.e., the single photons in the entangled two-photon states are ideally unpolarized. Nevertheless the preparation of the two-photon state as an entangled state implies the correlations as measured in all possible experiments. It's 100% (anti-)correlated if both A and B measure (or rather test for) linear polarization in the same direction.
DrChinese said:
@Fra:
d. You are incorrect about Bell's hidden variable types - there was no limitation or exclusion on them at all. He said (1964): "Let this more complete specification be effected by means of parameters λ. It is a matter of indifference in the following whether A denotes a single variable or a set, or even a set of functions, and whether the variables are discrete or continuous." He does provide one assumption however, but it is not on type or form: "The vital assumption is that the result B for particle 2 does not depend on the setting a, of the magnet for particle 1, nor [vice versa] A on b."
Separability means that the probabilities for the outcome of a joined measurement, given the value(s) of the hidden variable(s), ##\lambda##, commute, and that's indeed assumed in Bell's original paper (Eq. 2):
J. S. Bell, On the Einstein-Podolsky-Rosen paradox, Physics
1, 195 (1964),
https://doi.org/10.1103/PhysicsPhysiqueFizika.1.195
Of course the reduced probabilities, i.e., the integral/sum over ##\lambda## is not "separable".
  • #242
DrChinese said:
As you asked the question, there is no counterfactual to consider. This can be experimentally realized, so there's nothing to consider in the way of interpretations. It's a fact.
Say Alice measures the spin of her electron at some angle and observes "up". Is the following statement true:
"If bob performs the same measurement on his electron, there is a 100% chance he will observe 'up', but if Alice had not measured her particle, there would be less than 100% chance that Bob will observe 'up'"
The bit in bold is the counterfactual. I can also rephrase the question in terms of ensembles:
Given an ensemble of identically prepared electron pairs in the appropriate Bell state, Bob measures spin-x = up 50% of the time and spin-x = down 50% of the time. However, for the subensemble of experimental runs where Alice measures spin-x = up, Bob measures spin-x = up 100% of the time. The counterfactual: If, for this subensemble of experimental runs, Alice had chosen not to perform a measurement, Bob would have instead observed spin-x = up 50% of the time, not 100%
The conclusion of superluminal influence rests on counterfactual reasoning like this, but if this reasoning is not correct, then we cannot yet conclude superluminal influence.
@PeterDonis I was applying the counterfactual reasoning outlined in chapter 19 for supports like 19.12 (or 19.14) to the scenario I posed to @DrChinese to show that, under the consistent histories interpretation, no superluminal influence is implied. I will go through steps in more detail/more explicitly when I get the chance.
[edit] - Changed photons to electrons to keep my scenario physical
  • #243
Suppose the two photons are prepared in the polarization-singlet state, then the single-photon states are given by the corresponding partial traces. The outcome is ##\hat{\rho}_A=\frac{1}{2} \hat{1}_A##, ##\hat{\rho}_B=\frac{1}{2} \hat{1}_B##, i.e., the photons are perfectly unpolarized. All that A and B find when measuring the linear-polarization state both in the same direction are unpolarized photons, i.e., they find with 50% chance H and with 50% chance V. Only when their measurement protocols are storing the results of this measurement (together with the accurate time stamps to be able to know, which photon pair's where prepared as an entangled state when doing their measurements) you are able to "post-select" the subenemble, where A found H, and then, comparing the measurement protocols, it will come out that, given A found H, B always found V, i.e., a 100% anti-correlation, and that's precisely what the preparation in the entangled state implies. This measurement protocol establishes a measured fact. You cannot conclude anything about something, which could have been measured, but hasn't been measured.
  • #244
The "microcausality constraint" is that spacelike separated measurements must commute. That doesn't rule out a "mutual influence" altogether; it just means that any such "influence" cannot depend on the order in which the measurements occur. Some might say that rules out any "influence" at all, but others might disagree.
  • #245
PeterDonis said:
And the entangled state that was prepared. I don't understand why you keep leaving this out.
A: There is no variable from the entangled state (other than I guess a selection of type of conservation rule) that is a part of the quantum expectation value. Further, Bell ruled out predetermined elements of the superposition/entanglement as being an explanation of the outcome statistics. That only leaves things that happen from the first measurement to the second measurement (and regardless of order or reference frame) as being part of the mechanism we wish to understand. That's the time during which we go from an entangled 2 particle system to 2 systems of 1 particle. We don't know what happens during this period, when both particles end up in sharply defined spin states (if that is what we are measuring).
Only Alice and Bob's settings matter, that's the math. For polarization entangled photon pairs, the relevant term is: cos^2(theta) where theta is the difference between Alice's setting and Bob's setting.
  • #246
Yes, there is: the relative amplitudes of the terms in the entangled state. The only reason this doesn't appear in Bell's papers is that Bell assumed a particular entangled state (the singlet state) for which the ratio of amplitudes (or more precisely its squared modulus) is ##1## so it drops out of the formulas. But if we consider all possible entangled states of two qubits, the relative amplitudes of the terms in the particular entangled state we prepare will certainly contribute to the expectation value.
  • #247
It rules out causal connections between space-like separated events, because the time evolution in the Heisenberg picture is described by the equation of motion,
$$\partial_t \hat{O}(x)=\frac{1}{\mathrm{i}} [\hat{O(x)},\hat{H}],$$
where
$$\hat{H}=\int_{\mathbb{R}^3} \mathrm{d}^3 y \hat{\mathcal{H}}(t_y,\vec{y}).$$
Plugging this in the said equation of motion together with the microcausality constraint, which by construction holds particularly for the commutators of any local observable and the Hamilton density, the only contribution in the time evolution can come from arguments ##x## and ##y## that are light-like or time-like separated. Thus the commutation at space-like distances rules out causal actions over space-like separated events.
It's of course also true that the measurement results, including the correlations between local measurements at time-like separated measurement events, are not "time ordered" in any sense. You can always find an inertial frame, where the measurements are completed simultaneously. The temporal order of space-like separated events is frame-dependent, and that's why they cannot be causally connected by definition, and that's why one assumes the microcausality constraint and last but not least that's why it's called microcausality contraint.
  • #248
vanhees71 said:
the only contribution in the time evolution can come from arguments and that are light-like or time-like separated
What "time evolution" are we talking about? It looks to me like this concept in QFT as you are describing it is frame-dependent.
  • #249
Who cares if you *can* add variables in, that's a red herring. Bell tests don't do that! Reference:
https://arxiv.org/abs/quant-ph/9810080
"In a rather general form the CHSH inequality reads S(α, α′ , β, β′ ) = |E(α, β) − E(α ′ , β)| + +|E(α, β′ ) + E(α ′ , β′ )| ≤ 2. Quantum theory predicts a sinusoidal dependence for the coincidence rate Cqm++(α, β) ∝ sin2 (β − α) on the difference angle of the analyzer directions in Alice’s and Bob’s experiments."
I don't see anything other than settings for Alice and Bob. According to theory, and as far as can be determined from all experiments ever run: every individual entangled pair used in a Bell test is 100% identical in all respects to every other pair. This is canon. You'd have to agree with this, and as such, we are right back to where I started. Only Alice and Bob's settings matter. (And yes of course, you must be operating on entangled pairs - I am not questioning that particular point.)
  • #250
I'm not talking about "adding variables". An entangled state of two qubits will have at least two terms, and those terms will have relative amplitudes that have physical meaning. Those "variables" are already there. There's no need to "add" anything.
Bell test experiments and theoretical discussions, including the paper you reference, are all done using only a very limited number of all of the possible entangled states of the qubits involved. Those states, as I've already said, are constructed so the amplitudes of all the terms (or more precisely their squared moduli) are equal, so their ratios are ##1## and drop out of the formulas. That doesn't mean those "variables" aren't there; it just means the experiments and theoretical discussions are focused on particular states where those "variables" drop out of the formulas.
Of course not, because you're looking at the formula for states where all of the amplitudes of the terms are equal so their ratios drop out of the formulas.
If you want to see what happens when the amplitudes of the terms are not equal, try doing a similar analysis to the one that predicts violations of the CHSH inequality, but for this state:
\ket{\Psi} = \sqrt{\frac{1}{3}} \ket{H}_1 \ket{V}_2 + \sqrt{\frac{2}{3}} e^{i \varphi} \ket{V}_1 \ket{H}_2
  • #251
Yes, you COULD run an experiment where there is a mismatch between the terms and the outcomes are not balanced (more likely to be V than H or vice versa). So what? This has absolutely nothing to do with what is being discussed in this thread - nor anything to do with attempting to isolate what contributes to the theoretical quantum expectation value. What you are doing is going in the opposite direction from actual tests: we wish to factor out things like outside noise, source or detector inefficiency, distinguishability, any contribution other than the purest of entangled states; so we have the opportunity to locate any hypothetical deeper explanation for observed statistics.
As we do that, the settings of Alice and Bob are all that remain as inputs. Nothing else seems to matter, and we get that from theory as well as experiment. Again: every individual entangled pair used in a Bell test is 100% identical in all respects to every other pair (as far as we know, and as far as QM predicts). There is no suspected difference that satisfactorily accounts for, contributes to, or otherwise explains the outcomes of one trial run versus any other. Alice's individual results appear completely random, as do Bob's. And yet when Alice and Bob compare results when observing at identical settings, their results are perfectly synchronized. I have no idea why you would debate this point. This is all standard, we should be in complete agreement.
  • #252
I think this is a matter of opinion. You are of course free to ignore what I'm posting if you think this.
This is obviously false since if we do consider other entangled states, the relative amplitudes of the terms certainly will contribute to the theoretical quantum expectation value. The fact that experiments to date and the literature in general has not considered such states does not mean they don't exist.
I understand that this is why experiments to date and the literature in general have focused on particular entangled states like the singlet state. And if you had limited your claim about what "contributes" to the expectation value to those states, that would have been fine. But you didn't. As a fully general claim about an arbitrary entangled state, your statement that the entangled state itself does not contribute to the quantum expectation value is simply false. That's why I objected to it.
  • #253
It is not because of the microcausality condition! That's another reason for assuming it.
  • #254
The equations you wrote down are written in some particular frame; that's where the ##t## in the first equation and the ##\mathbb{R}^3## that is integrated over in the second come from.
Is the idea that the microcausality condition ensures that these equations are valid regardless of what frame you pick?
  • #255
PeterDonis said:
I'm not talking about "adding variables". An entangled state of two qubits will have at least two terms, and those terms will have relative amplitudes that have physical meaning. Those "variables" are already there. There's no need to "add" anything.Bell test experiments and theoretical discussions, including the paper you reference, are all done using only a very limited number of all of the possible entangled states of the qubits involved. Those states, as I've already said, are constructed so the amplitudes of all the terms (or more precisely their squared moduli) are equal, so their ratios are ##1## and drop out of the formulas. That doesn't mean those "variables" aren't there; it just means the experiments and theoretical discussions are focused on particular states where those "variables" drop out of the formulas.Of course not, because you're looking at the formula for states where all of the amplitudes of the terms are equal so their ratios drop out of the formulas.
When dealing with photons or other relativistic particles we should rather write this as
$$\ket{\Psi} = \left [\sqrt{\frac{1}{3}} \hat{a}^{\dagger}(\vec{p}_1,H) \hat{a}^{\dagger}(\vec{p}_2,V) + \sqrt{\frac{2}{3}} \exp(\mathrm{i} \varphi) \hat{a}^{\dagger}(\vec{p}_1,V) \hat{a}^{\dagger}(\vec{p}_2,H) \right] \ket{\Omega},$$
where ##\ket{\Omega}## is the vacuum state. This ensures that we take into account properly the Bose properties of photons.
  • #256
Imposing the equal-time commutation relations of canonical quantization in one frame together with Poincare covariance implies the microcausality condition and ensures the Poincare covariance of observables. For a very thorough discussion of all this, see
A. Duncan, The conceptual framework of quantum field
theory, Oxford University Press, Oxford (2012).
  • #257
I think the likely reason for Bells ansatz is that he is not just trying to see if some sort of hidden variable, can explain the correlation within the context of some causal quantum mechanisms, but he is implicitly trying to recover full determinism.
Bell rules out hidden variables that (if known) in principles recovers determinism of the probabilities, and explain statistic as averaging over classical actions.
But Bell does not rule out hidden variables that account for correlation, where the probabilities involve non-classical actions, ones that does not lend themselves to be indexed by a hidden variable that can in principle be sampled. Such hidden variables are stranger to conceptualize as they are not of ignorance type? Conceptually I think of this as information shared only between the two entangled system. So if you would have an hypothetical "inside observer" as one of the entangled parts, this would be observable by it, but not by external observers. The external observer sees just the "entangled system" as one unit. A theory of this sort is not excluded by Bell. Of course this is essentially what QM is, but the difference is that we do not understand QM in this way, or at all! That is essentially my only point.
The idea that there is some stuff going on between A and B, between their observations seems to be the direction you entertain. But it seems very strange to me, to the point that I don't understand the vision.
/Fredrik
  • #258
I'd rather say, Bell rules out the assumption that all observables of a system always take determined values, i.e., that the values of observables are deterministic. The quantum state is "deterministic" also in QT in the sense that for a given initial state at time ##t_0## and given the Hamiltonian of the system, the state is determined at any later time ##t##. The indeterminism of the observables comes from the probabilistic meaning of the quantum states in standard QT.
What's for sure is that, within microcausal relativistic QFT, there is not "going on some stuff" between A and B, if A and B are spacelike separated.
  • #259
I was going to object at first, but then I realized that by "observables" having "determined values" you probably mean that it can be communicated into the classical domain, be poincare invariants, and become "common knowledge" and shared. Then I agree.
But I entertained the concept of a different kind of HV, something that is not "observable" in the sense of QFT, but still having all the standards of that they have been inferred and encoded. It's just similar to that I can KNOW something that you do not, and vice versa. But my actions are independent of what YOU know, and your actions are independent of what I Know - regardless of wether the information is correct or not. So all the locality is built in the hard way. But not not referencing 3Dspace, but some "information"space. ie. two observers are at the same point iff they have the same information, which would make them indistinguishable. In this sense, certain HV can have determined values with respect to the entangled parts itself, but not to anyone else. That isn't ruled out by bells theorem, because it makes not sense to partition the interaction based one someone elses decomposistion. It's a invalid mixing of inference elements as I see it. As far as I understand Demystifier, this seems a similar concept as what he called solipsist HV. I am not at all in line with that bohmian stuff, but I just find the conceptual analogy interesting.
My point is that these "solipsist HV", does not have the same causal role as the "ignorance type HV", their determinsation are not "classical knowledge" that is averaged out, or "ignored". But they can still serve as as conceptual explanation of that the correlation is defined when the entangled pair is created. But it does not mean that the physics as the detector can be paritioned as ignorance action sum.
/Fredrik
  • #260
I think that the idea of "hidden variables" is that they are not observable but determine the values of the observables and are themselves determined, and we just cannot know their values (for whatever reasons) and thus treat them probabilistically. The strength of Bell's argument, of course, is that the conclusion that such a deterministic and local theory contradicts the probabilistic predictions of QT for entangled states and specific measurements, is independent of the concrete probabilities (or probability distributions) one assumes for these hidden variables.
  • #261
While this describes well the "naive causality" we are used to and the historical reasoning around this. The idea comes out as irrational from the perspective of inference as I see it:
If observables are determined by hidden variables, it means there exists a deductive scheme for this.
To rationally beeing able to abduce this deductive scheme in the first place, we must be able to "observe" the hidden variables and the observables to find the rule but fitting data. But now we can not do so because we somehow can not observe these hidden variables, perhaps because nature physically limits our inference. IF this is the case, there is not rational empirical justification (within the inference) for expecting the existence of this deductive rule? ie. this idea appear irrational.
The only way this can make any sense is if we actually CAN observe the hidden variables (but don't due to our ignorance or because we CHOOSE to average them out).
/Fredrik
  • #262
One should also clearly destinghish between "causality" (be it naive or not) and "determinism":
Causality means that if you know the state of a system at all times ##t<t_0##, then the state of the system is known (can in principle be calculated) uniquely at all times ##t>t_0##. On the fundamental level, we even have a stronger kind of causality, because it's sufficient to know the state of the system at one point ##t=t_0## to know the state at all later times ##t>t_0##.
Determinism means that all physical observables always take precise values. That's the case for classical physical theories, be it for discrete (point-particle mechanics) or continuous observables (fields). In deterministic theories the state is described by the determined values of the observables, within classical theories there's no need to distinguish between causality and determinism, because both together mean that when knowing the values of all observables (or of all independent observables, out of which all other observables can be calculated using well-defined functions) at all times ##t \leq t_0##, one also knows the values of all observables at all later times ##t>t_0##. On a fundamental level (Newtonian or relativistic point-particle mechanics, classical electrodynamics) again the stronger "time-local" initial condition is sufficient.
I think the big quibble for the physicists at the time when modern QT has been discovered, leading to Born's probabilistic interpreation of the quantum state, indeed was that now one had a causal theory but indeterminism, i.e., the state of a system does not imply the determinism of all observables and even more, the impossibility to prepare the system in any state, where all observables take determined values (Heisenberg's uncertainty relations).
This would have to be worked out in detail, if there were any necessity for it, but to the contrary it's not necessary, because quantum theory turned out to describe all phenomena correctly. This also implies that it is impossible to find out, within "local realistic HV theories" how such a deductive scheme should look like, i.e., there's no way to empirically get hints for building a concrete model (and be it "only" probabilistic!) nor is there the possibility to empirically test any given such model.
Precisely! There's no need for hidden variables and their meaning and behavior cannot be empirically tested. As with the aether of the 19th century with the discovery of (special) relativity, it's more economic and much simpler, to simply say "hidden variables don't exist".
/Fredrik
That's indeed what was behind this idea of hidden variables: It's as with classical statistical physics. We use statistical descriptions only to describe some coarse-grained "macroscopic observables" as "averages over a lot of microscopic observables", we cannot resolve anyway (neither theoretically in our models nor by observations).
  • #263
I agree with all except...
Yes, that is exactly what I try todo as well.
This sounds like some stronger causal determinism to me? By causality I mean that the future depends on the past(lightcone) as per some sort of logic/scheme(not necessarily deductive), and NOT on some ad hoc stuff. The past can induce a probability distribution of the future, I think of that as causality as well.
(As a reference: In my agent interpretation, I take causality to mean the action of the agent depends on (but is not deductively determined by) it's current state, meaing it responds to what it is informed about only. Locality supposedly follows from the same principles, once spacetime emerges, but causality is more fundamental than locality)
For me "determinism" is equivalent to "deductive causation". Ie. a unique initial condition leads always to a unique future state. Ie. the whole timehistory is just "one" piece of information. Also as you say, in this scheme, the notion of "causation" becomes meaningless as everything is determined, so there is not really any way to "explain" mechanisms. (the ultimately consistent view here would lead to superdeterminism which I find irrational for other reasons)
As you wrote yourself, if one considers individual events, then QM is indeterministic. But as the "state" in QM is "probabilistic", and evolves deterministically its still deterministic in that sense, and it's how I view it.
I personally don't think of HUP as implying "indeterminism". As the conjugate variables are not commuting, they are not even by construction supposed to be known at the same time, that is the whole point of them beeing conjugate and I see them as different ways to encode the same information. No one would even ask why we can not know the frequency and the time at the same time. How come these conjugate codes are utilized by nature, is one of the things remaining to be understood in terms of some choice of paradigm (my choice is physical inference, others like geometry or other things). It's part of the quest for causal mechanism. But when I say that I do not mean searching for determinism. Then there has probably been a big misunderstandings in plenty of past threads?
/Fredrik
  • #264
Sure, that's why QT is perfectly causal. The state is represented by the statistical operator, which can be computed given the initial condition at ##t=t_0## at any later time ##t>t_0## (note that we have the stronger case that you don't know the entire history but only the state at one point in time ##t_0##).
It's not so clear to me, what you mean by "agent".
Fra said:
For me "determinism" is equivalent to "deductive causation". Ie. a unique initial condition leads always to a unique future state. Ie. the whole timehistory is just "one" piece of information. Also as you say, in this scheme, the notion of "causation" becomes meaningless as everything is determined, so there is not really any way to "explain" mechanisms. (the ultimately consistent view here would lead to superdeterminism)
I think this coincides with what I tried to say. However, I don't know what you mean by "explain mechanisms".
The state in QM provides the probabilities for the outcome of measurements. QM is indeterministic, because not all observables can take determined values. Only compatible observables can take determined values when the system is prepared in a corresponding state. If you choose a complete set of compatible observables, then the state is a unique pure state, and that's a state of "complete information", but still this "complete information" does not mean that all observables take determined values.
That's also not entirely true. There can be states, where non-commuting observables have determined values. E.g., if you have ##J=0## all components of the angular momentum take the determined value ##0## although the components don't commute. The information (state) about the system is not "encoded" in the values of observables uniquely but in the statistical operator.
Frequency (energy) and time are a very bad example since time is not an observable in quantum mechanics, and the "uncertainty relation" between time and energy has a different meaning than the Heisenberg uncertainty relation for observables. See Appendix B in
https://arxiv.org/abs/2207.04898
  • #265
Please be advised that personal theories and interpretations are off limits. Even in the QM interpretations forum (which this is not), only interpretations that appear in the published literature can be discussed.
  • #266
PeterDonis said:
Huh? That scenario, like all of the scenarios discussed in that chapter, is about a measurement on a single particle. None of them are about measurements on entangled pairs of particles.
Even if we leave that aside, the only scenario that even discusses counterfactuals where a measurement that is made in the "actual" world is not made in a counterfactual world is the one shown in equation 19.14.
Consider the scenario: A particle pair is prepared in the state ##\frac{1}{\sqrt{2}}(|x_1^+x_2^+\rangle + |x_1^-x_2^-\rangle)## and one particle is given to Alice and Bob each (subscripts ##a## and ##b## will denote alice and bob respectively). Bob always measures spin-x of his particle with his apparatus ##X_b##. Alice either measures spin-x of her particle with her apparatus ##X_a##, or she performs no measurement by swinging her apparatus out of the way (we'll denote the apparatus in this state with the symbol ##N_a##).
The question we want to answer: "Bob and Alice measure their particles and obtain the respective spin-x = up results ##x_a^+,x_b^+##. Would Bob have definitely obtained the same result if Alice had instead swung her apparatus out of the way?"
To build an appropriate family of histories, we'll consider three times ##t_1,t_2,t_3##. We have a history space ##\mathcal{H}_{t_1}\otimes\mathcal{H}_{t_2}\otimes\mathcal{H}_{t_3}## with identity operator ##I_{t_1}\otimes I_{t_2}\otimes I_{t_3}##.
At ##t_1## we consider assertions about the spin-x of Bob's particle. It has spin up or down so we projectively decompose the identity into these two possibilities ##\left\{[x_b^+]_{t_1}\otimes I_{a,t_1},[x_b^-]\otimes I_{a,t_1}\right\}## where ##I_a## denotes the identity operator on the space of Alice's particle.
At ##t_2##, Alice's apparatus is in position (##X_a^0##) or it isn't (##N_a##), so we use the decomposition ##\left\{[X_a^0]\otimes I_{b,t_2},[N_a]\otimes I_{b,t_2} \right\}##
At ##t_3## we account for the measurement outcomes appropriate for each history. We end up with the support
$$\left\{\begin{array}{lll}
\left[x_b^+\right]_{t_1}&\otimes&\left\{\begin{array}{lll}\left[X_a^0\right]_{t_2}&\otimes&\left[X_a^+,X_b^+\right]_{t_3}\\
\left[N_a\right]_{t_2}&\otimes&\left[X_b^+\right]_{t_3}\end{array}\right.\\
\left[x_b^-\right]_{t_1}&\otimes&\left\{\begin{array}{lll}\left[X_a^0\right]_{t_2}&\otimes&\left[X_a^-,X_b^-\right]_{t_3}\\
\left[N_a\right]_{t_2}&\otimes&\left[X_b^-\right]_{t_3}\end{array}\right.
\end{array}\right.$$
I have suppressed the identity operators ##I_a,I_b## in the above notation to make it more readable. We use this support to navigate counterfactual reasoning described in chapter 19 of consistent quantum theory. Bob and Alice have both measured spin-x = up, meaning we are on the top branch of this support. If we pose the counterfactual of Alice deciding not to measure her particle, we go backwards to ##t_2## and pivot to that alternative, the 2nd branch, and see that Bob still would have obtained the same result.
To paraphrase Murray Gell-Mann here
"People say, loosely, crudely, wrongly, that Alice's measurement does something to Bob's particle. It doesn't. Alice measuring her particle and not measuring her particle happen on different branches of history, decoherent with each other, only one of which occurs."
  • #267
Yes, but that's because you picked the ordering of what to specify to make that result come out. Changing the ordering would change the result. Your ordering is equivalent to claiming that Bob's particle has a definite spin before Alice chooses whether or not to make her measurement. But what justifies that claim?
  • #268
Nothing. If the particles are in a Bell state, the single-particle properties are maximally indetermined, i.e., their "reduced state" is a state of maximum entropy. E.g., if you have spin-1/2 particles, then Bob will simply measure ideally unpolarized particles, no matter what Alice does with her particle. If Alice doesn't measure anything, you also cannot choose subensembles from the measurement protocols taken by both experimenters, and you can never observe that the two particles were prepared in an entangled state. It's a trivial example for the rule that in quantum theory you describe experiments which are really done, and speculating about what might have been measured but isn't really measured either leads to confusion or it's something trivial.
  • #269
The only "probabilities" that I think are physically intereting are the expectations (ie the optimally infered probability for it's future observations) any given specificed observer can make, from the information it has.
As soon as one starts to mix and filter collected "classical data" post-mesaurement from different observers, one gets a descriptive probability, but one that does not correspond to and expectation having the normal form. So what are we supposed to compare it with? This only makes confusion.
As long as we stick to one observer, the expectations post-measurement, should be consistent with the post-measurement descriptive probability (statistics). But when one started to mix and filter data post-measuremnet, there is nothing to level it against?
/Fredrik
  • #270
Then you cannot make coincidence measurements, or what? It doesn't make sense to forbid experimentalists to measure whatever they want for some strange philosophical reason. It's the obligation of theory to describe all kinds of experiments, including coincidence measurements on subsystems of an entangled system.
  • · Replies 57 ·
  • · Replies 24 ·
