Entropy, event reversal, and a paradox
  • Thread starter Thread starter brain pickeR
    Entropy Paradox
The discussion centers on the confusion surrounding the concept of entropy, particularly in relation to the freezing of water into ice. While freezing decreases the entropy of the water, it releases heat to the surroundings, which increases the entropy of the environment, maintaining the overall increase in entropy in the universe. The conversation highlights that spontaneous processes, like freezing, are highly improbable without external influence, emphasizing the second law of thermodynamics. It is noted that the amount of heat removed during freezing contributes to the entropy change, and that the entropy of the universe always increases in such processes. The complexities of entropy and its implications for natural processes are clarified through examples and calculations.
brain pickeR
I'm having difficulty understanding the temporal symmetry of entropy described in Fabric of the Cosmos. The increase into the future is easy enough to accept, but in the same equation we see it decrease from the past to the present. Am I to accept that there is an equal chance of some magical force lowering the entropy of water by creating ice, as there is of a force increasing the entropy of ice by melting it?
Something ain't right.
Science news on Phys.org
hell ya... even I'm confused now... i thot more mess less energy was the way of life... but turns out that when water freezes to ice, it loses energy and entropy decreases... what the hell? SOME1 HELP HERE!
ok cool... here's the answer... i found it at http://jchemed.chem.wisc.edu/JCESoft/CCA/CCA3/MAIN/ENTROPY/PAGE1.HTM
See... entropy decreases when ice freezes and energy decreases... true... but entropy concept just tells us that this phenomenon occurring spontaneously is highly improbable... its simply impossible for steam to condense to boiling water and then freeze to ice all by itself... Thus entropy is a quantity that reflects our empirical knowlegde about the direction of natural processes. Everything else (pressure,etc)
held constant, a given amount of heat added to a hot body increases its entropy less than when added to a cold body.
the following i got from http://www.maxwellian.demon.co.uk/art/eia/
Melting point, heat of melting
As an application of these conclusions, let's see if we can explain why there is something like a melting point. Refer to example no. 8; entropy is lowered upon freezing. But isn't freezing a natural process? And didn't we learn that for natural proceses, entropy increases?
It does. Keep in mind that we have excluded from consideration the heat of melting that is released when something freezes. Now we have to look at the entropy effects of this released heat.
Let us place the box of example no. 8 in a heat insulated vessel, containing, say, a very large amount of ethanol (it does not freeze itself at -2 °C). As soon as the water in the box freezes, a large amount of heat is set free; it warms up the freezing water to 0 °C (this is why temperature of freezing water is always 0 °C at normal pressure) and the excess is transferred to its surroundings, the ethanol in this case. Since we have very much ethanol, its temperature does not rise appreciably. So the ice at 0 °C eventually cools down to -2 °C; that is why we can avoid entropy effects of temperature change and focus on those of phase change. Thus total heat of melting is transferred to the ethanol, increasing its entropy.
The increase of entropy of ethanol must balance out the decrease of entropy when the ice is formed. Otherwise the process would not take place. In fact, if you prevent this heat from leaving the system, the substance in it would not freeze, at least not completely.
Now we have learned that the same amount of heat added to a cold body increases its entropy more than when added to a hot body. It follows that there must exist a temperature T(0), above which the entropy increase of the surroundings is not enough to balance out the decrease of the freezing water. Beneath T(0), entropy increase of surroundings is higher, and at T(0) entropy changes of freezing water and of surroundings are exactly equal. This is exactly how we defined entropy at the top of this article:
i got this question from...http://people.ouc.bc.ca/woodcock/121-notes/quiz6_answers.htm
4a. Calculate the entropy change when 1 mole of water freezes at 0º C. The heat of fusion for water is 6.01 kJ/mol.
Note: watch the units. The usual units for entropy change are J/mol.K, whilst those for enthalpy change are kJ/mol.
For a phase change: DS = DH / T = 6010 J / mol / 273 K = 22.0 J /mol.K.
To put it maybe a little simpler, to freeze water into ice requires removing heat. Some of that heat is entropy (if you use a freezer, you create a good 3x more waste heat than you've rememved from the ice). So while the entropy of the ice is lower than the entropy of the water, the 2nd law of thermo is about the universe itself: the entropy of the universe has increased during the process.
And yes, while the 2nd law is a macroscopic principle, on the very small scale, there can be temporary reversals, but like you said - they are very improbable even on the small scale.
Thanks, now I understand the graph.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
