Equal to zero if angular velocity is constant
24 replies · 5K views
darkmagic
Which is equal to zero if angular velocity is constant, normal or tangential acceleration?
The one with zero angular velocity is a crank. The crank moves at a fixed point.
I think it is the tangential one because that means it is a uniform motion but continuously changing speed? is that correct?
But it is not changing speed, the angular velocity is the same.
At different points in the circular motion, if you draw a tangent to the circle, you will get the direction of velocity right? Does this tangent always point in the same direction?
sorry it should be constant velocity. changing direction but constant speed, right?
Yes. So would the tangential velocity be changing is α is defined as α=dω/dt ? Since the direction of the tangential velocity is changing what does that say about acceleration?
velocity is changing. If that is changing, acceleration is also changing?
Right so if you were to draw the two velocity tangents and then find the change in velocity, it would point towards the center of rotation. So which acceleration is zero?
Normal acceleration is always towards the fixed point. The normal one?
That would be correct.
Can you give a summary on how to determine which is zero among the two in different situations?
How can I determine the tangential acceleration if I have given the angular velocity?
tangential acceleration is related to α by atangential=αr
so, if normal is zero, then tangential equals the angular acceleration. I only depend on the tangential and normal formula.
no no, the only way for your normal acceleration to be zero is if the object is not spinning. Remember a=ω2r
darkmagic said:
so normal is zero in a sliding block?
You mean a sliding block on a curved surface? No, the normal is not zero. In that case there is still a normal acceleration.
i mean in a mechanism, in a flat surface. the sliding block has zero normal? I'll be back.
Once your object is basically rotating with respect to some point, there will be a normal acceleration.
I mean in a mechanism, the sliding block, the normal in a flat surface is zero?
ok, what sort of mechanism are you talking about?
darkmagic said:
its only a sample, only a schematic drawing.
Can you post a picture of the schematic?
its only a sketch angular velocity at 2 is constant
If your surface is flat in that manner, then there is no normal acceleration.
