Equation for the motion of an iron particle in a magnetic field
The motion of a small iron particle in a magnetic field is influenced by the gradient of the magnetic field density. When positioned centrally above a stick magnet, the particle will move directly toward the center of the magnet. However, if placed slightly off-center, the particle experiences a non-vertical force that causes it to approach the magnet at an angle rather than along the shortest path. The discussion seeks to identify the mathematical equation that describes this trajectory. Understanding the particle's path requires analyzing the magnetic field's influence on its motion.
ddddd28
Hello,
Let's assume we put a small iron particle in a magnetic field. What is the equation of the route that the particle performs? Is it the minimal route length that is possible? (the magnet is a stick-form)
It might look that way, but I don't think so.
As a general rule, the particle will experience an attraction in the direction of the biggest field density increase. That however means for example, if you place it right in the middle between the poles but above the bar, all it will do is go straight towards the middle of the bar. But, if you place it slightly say to the right of that point, the direction of attraction will sightly point towards to the right because the field lines also get more dense towards that direction.
So, in essence, slightly off-center the particle experiences a non-vertical force, which will make it hit the bar at an angle. That then obviously is not the direct route.
I wanted to know which mathematical equation describes the route
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
