Equation of a Parabola: Can Any Point on the Graph Satisfy the General Equation?
  • Thread starter Thread starter kevinshen18
    Parabola
The general equation of a parabola is (y - y1) = A(x - x1)^2, where A is the scaling factor, and (x1, y1) is the vertex. Any point (x, y) that satisfies this equation lies on the parabola. Specifically, if x - x1 = 0 and y - y1 = 0, then (x, y) is the vertex of the parabola. The equation allows for generating infinite points on the curve without listing them individually. Thus, points on the parabola are defined by the equation rather than being arbitrary coordinates in the plane.
kevinshen18
The general equation of a parabola is:
y1 is the y coordinate of a vertex/point on the parabola
x1 is the x coordinate of a vertex/point on the parabola
My two questions are:
1. Can (x,y) be any point on the graph ?
2. If so, then if x - x1 = 0 and y- y1 = 0 (if the difference between the points are 0) then does that mean the point (x,y) is on the parabola?
Mathematics news on Phys.org
Yes, (x, y) refers to any point on the parabola.
Your question is a little confusing (or confused). Again, (x, y) can refer to any point on the parabola. "if x- x1= 0 and y- y1= 0" then x= x1 and y= y1 is a specific point on the parabola. In fact, it is the vertex of the parabola- the lowest point if A is positive, highest point if A is negative.
That's what the equations of these curves are for.
Instead of having to compile a list of the infinite number of point coordinates which fall on the curve, a simple equation can be used to generate one point or many points, all of which will fall on the curve
Any point (x,y) which satisfies the equation of the parabola is a point on that parabola.
Now, why all of this confusion?
I would say that (x,y) is some point in the x,y plane, may on the parabola maybe not.
Points on a parabola are given by: (x, (x-x1)2+ y1))
In the original post the reference was to (x, y) satisfying the equation (y- y_1)= A(x- x_1)^2.
Those (x, y) are points on the parabola, not arbitrary points in the plane.
Thanks guys. So if (x,y) = (x1,y1), then this satisfies the parabola equation and (x1,y1) is the vertex?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
