Equation of magnetic field produced by a solenoid
The discussion revolves around determining the equation for the magnetic field strength produced by a solenoid at a distance from it, specifically focusing on the field outside the solenoid in the xy-plane. Participants explore the form of the equation and its components, as well as the underlying physics concepts related to magnetic dipoles.
  • Participants discuss the general form of the magnetic field equation and express difficulty in finding a suitable formula without complex components. There are inquiries about the meaning and calculation of the magnetic moment, as well as the relevance of various parameters such as the number of turns, radius, and current of the solenoid.
The conversation includes various suggestions and clarifications regarding the magnetic dipole approximation and its applicability. Some participants provide equations for the magnetic field components and discuss the conditions under which these approximations hold. There is an ongoing exploration of the geometry of the problem, with requests for additional details from the original poster.
Participants note that the magnetic field equations may vary based on the distance from the solenoid and the orientation of the solenoid itself. There is mention of the assumptions required for the dipole approximation to be valid, as well as the potential differences in behavior at close versus far distances from the solenoid.
kregg34
For a lab we need the equation of the magnetic field strength produced by a solenoid a distance r away from it (outside of it). I tried looking online and couldn't find one that didn't involve a bunch of cross products or similar. Wonder if anyone knows the formula? I know its of the form B(r) = (1/r^3)((some stuff*unit vector in r direction) + (some stuff*unit vector in θ direction)). The experiment only looked at the field strength in the xy-plane (or in polar the rθ-plane) so I do not need the third unit vector in the B(r) equation.
My professor said we can find it online but no luck.
Google "magnetic dipole". There will be a constant scaling factor that is determined by the geometry of the solenoid including the number of turns, the radius, and the current.
Ok I found two equations for the two components, (y is perpendicular to coil, z is parallel)
B(in y) =(|μ|/r^3)*(3cos(θ)-1)
B(in z) =(3|μ|/r^3)*(sin(θ)cos(θ))
but what is μ and how do I calculate it?
Magnetic moment ## \mu=N \, I \, A/c ## in c.g.s. units where ## A ## is the cross-sectional area of the solenoid.. I'll need to look it up to see what the constants are in M.K.S. units. Incidentally, the magnetic dipole formula only works well for medium distances or larger. At close range the magnetic field of a solenoid obeys other formulas. e.g. the magnetic field inside a long solenoid is nearly uniform and is given by ## B=\mu_o n \, I ## where ## n=N/L ## and points in the z direction (in the direction of the axis of the solenoid). Also, in general, the magnetic field inside a solenoid is usually of much more interest than the magnetic field outside of a solenoid at a large distance from it. If your distance ## r ## meanwhile is measured from one opening of the solenoid and is not large compared to the length of the solenoid, you will see an inverse square law for the fall-off of the magnetic field strength with distance i.e. especially on axis as you move away from the exit aperture. Could you please supply some additional info of the geometry of the problem? It could be quite relevant=what was the length ## L ## of the solenoid, what was the radius "a" of the solenoid , and what range did your distance ## r ## cover and where was it measured from? Also, how many turns ## N ## did the solenoid have and what was the current ## I ## ? editing... I would try googling magnetic dipole one more time. Wikipedia does a good job (M.K.S.) and defines ## m=NIS ## (## m ## instead of ## \mu ##, with ## S ## in place of ## A ##), and their formulas for ## B ## have a ## \mu_o/(4 \pi) ## multiplying expressions similar to what you presented. Also your formulas are incorrect. It should read ## B_z=m(\mu_o/(4 \pi))(3 cos^2(\theta)-1)/|r|^3 ## and ## B_y=m(\mu_o/(4 \pi))3 sin(\theta)cos(\theta)/|r|^3 ##. If your distance ## r ## was measured from the center of the solenoid and was a good deal larger than the length of the solenoid, these formulas should be reasonably good.
Note in the above that ## \theta ## is measured from the z-axis. Hopefully the formulas are in good agreement with your data. Additional note is the professor may be trying to get you acquainted with microscopic(atomic-size) magnetic dipoles, and this is an experiment with a macroscopic one.
Computing off-axis magnetic fields of solenoids outside the solenoid is prohibitively difficult, so I assume you're looking for the on-axis B field outside the solenoid.
A standard way is to use Biot-Savart; you can either sum the contributions of each winding to the observation point or, more elegantly, you can approximate by assuming an arbitrarily large number of windings N of arbitrarily small current Δi such that N Δi = no. of turns x current of the solenoid. The latter approach works better the more number of (equally spaced) turns of the solenoid per unit length.
It appears the instructor doesn't expect them to do an exact calculation, but wants them to use the magnetic dipole formulation which assumes the field from the solenoid can be approximated by one plus magnetic pole at the center of one exit aperture and a minus magnetic pole at the center of the other. With the proper geometry at a large enough distance from the solenoid, this can be a good approximation. It's not exact, but that's apparently what their instructor is looking for. It would be interesting to hear from the OP again to give us additional feedback.
OK. How do you visualize how the solenoid is oriented? Axis = x axis, solenoid running from -L/2 to +L/2? Or is L infinite and the distance vector is in the y-z plane?
Solenoid is oriented along the z-axis. ## \theta ## is measured from the z-axis. ## L ## is finite, and the shorter, the better. ## \\ ## Additional note: The computation of the field is exact outside the solenoid if one assumes a plus pole evenly distributed across one aperture and a minus pole evenly distributed across the other aperture with the inverse square law. In any case, the dipole formulas are approximations that are reasonably good. They assume the poles are centered at the center of the aperture and that ## r>>L/2 ##. Under these conditions, the dipole formulas are readily derived.
OK. Not really intro physics IMO.
It looks like a rather interesting laboratory experiment, but the professor should provide the necessary equations and not expect them to google something that is this advanced. Most would probably have little luck in finding it. They would have no idea what to google.
Yeah, and I find the idea of using the mag moment dubious. A winding far away counts just as much as a winding close-by, which I guess is why you said 'the shorter the better" in regard to solenoid length.
The magnetic field from a magnetic moment follows an inverse cube formula for the far field, and there's likely to be only a limited range where the field from the solenoid is far in excess of the Earth's magnetic field. In a number of ways, the field inside the field inside the solenoid is of much more interest, but I think the professor might be trying to teach them about atomic magnetic dipoles and perhaps even magnetic surface currents. In Griffith's E&M textbook, Griffith's shows that the net effect (the magnetic field) of a uniform collection (billions) of (aligned) magnetic dipoles is equivalent to having magnetic surface currents around the surface of the magnetic solid. The magnetic surface currents can be used to compute the magnetic field of a permanent magnet. We'll need to get further feedback from the OP to see if this might be the impetus of all this.
