Equation of motion from given 2D Potential
Adoniram
A particle of mass m moves in two dimensions under the following potential energy
function:
V(##\vec{r}##) = ½ k (x2 + 4y2)
Find the resulting motion, given the initial condition at t=0:
x = a, y = 0, x' = 0, y' = vo
F = ma = -dV/dr
This will obviously involve a 2nd order diff eq, and there are enough initial conditions to solve for the unknown constants. If the potential were given with the r variable instead of x and y, it would be simpler. As such, I'm not sure how to take dV/dr when V is V(x,y) not V(r)...
If I use x = r Cosθ, y = r Sinθ, I can put it as:
V(##\vec{r}##) = (3/2) k r2 Sin2θ
But now that I have θ in the formula, is it ok to take dV/dr as such and set it in F = -dV/dr?
You are doing it the wrong way, there are vector involved and ##\frac{d}{d \vec r} = \nabla ## and everyone already says it: force is the gradient of the potential, can you work it out now ?
[Edit: In case I wasn't clear, ##\nabla = \lt \frac{\partial}{\partial x}, \frac{\partial}{\partial y} \gt ## ]
*facepalm* Thank you!
##\vec{F}## = -k( x ##\hat{x}## + 4y ##\hat{y}##)
Then set to m##\vec{a}## = m(##\ddot{x}## ##\hat{x}## + ##\ddot{y}## ##\hat{y}##), and compare associated vector components... yes?
Just tried that, for anyone who wants to check:
X(t) = a ##\cos##(##\sqrt{k/m} t##)
Y(t) =##\frac{v_{o}}{\sqrt{4k/m}}\sin(\sqrt{4k/m} t)##
