MHB Finding the Equation of a Line with Given Slope and Y-Intercept
  • Thread starter Thread starter mathdad
The equation of the line with a slope of 14 and a y-intercept of 0 is y = 14x. This line indeed passes through the origin, as all lines of the form y = mx do. For any value of x, the corresponding point on the line can be calculated using the equation. Specifically, when x equals 0, the point is (0,0), confirming it goes through the origin. This reinforces the understanding of linear equations in slope-intercept form.
mathdad
Given slope = 14; y-intercept is 0, find the equation of the line.
Solution:
y = mx + b
y = 14x + 0
y = 14x
The equation of the line is y = 14x.
Correct?
Mathematics news on Phys.org
Of course it is!
Does the line y = 14x go through the origin?
All lines of the form $y=mx$ go through the origin...for any $x=a$, the point $(a,ma)$ is on the line...what point do we get if $a=0$?
Good information for my notes.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
