Equations Involving Radicals Question
  • Thread starter Thread starter HerroFish
    Radicals
The discussion revolves around solving the equation √(x-7) / (√(x) - 2) = √2. The initial attempt led to an incorrect quadratic equation, 0 = x^2 - 64x + 225, which was questioned by other participants. It was clarified that proper use of parentheses is crucial for accurately interpreting the equation. A suggestion was made to rearrange the equation to isolate the radical before squaring both sides. The importance of clear notation in mathematical expressions was emphasized to avoid confusion in problem-solving.
HerroFish
Solve for:
√(x-7) / √(x) -2 = √2
My attempt at a solution:
I solved for x and it comes out to:
0 = x^2 - 64x +225
and then i plugged it into the quadratic formula:
[-(-64)±√((64)^2-4(1)(225))]/2
and my answer comes out to be:
32±√799
although the answer on the back of the package is 9 and 25.
kind of confused on how to attempt this question now and not sure what I'm doing wrong...
And thanks in advance for the help!
HerroFish said:
Solve for:
0 = x^2 - 64x +225
32±√799
0 = x^2 - 64x +225 isn't the right quadratic. Check it again or show how you got it.
(√(x-7)) / (√(x) - 2) = √2
√(x-7) = √(2) (√(x) - 2)
x-7 = (√2x - 2√2) ^2 <------- square both sides
x-7 = (√2x)^2 - 2(√2x)(2√2) + (√8)^2
x-7 = 2x - 8√x + 8
0 = x - 8√x +15
0 = x^2 - 64x + 225 <----- squared both sides to get rid of radical
and plug into quadratic eqn. :P
HerroFish said:
Solve for:
Is the problem your working on,
\displaystyle \frac{\sqrt{x-7\,}}{\sqrt{x\,}-2}=\sqrt{2} \ ?
Or is it \displaystyle \frac{\sqrt{x-7\,}}{\sqrt{x\,}}-2=\sqrt{2} \ ? which is literally what you wrote.
the first one
Sorry i don't really know how to use the square root sign, pretty new to this
x-7 = 2x - 8√x + 8
0 = x - 8√x +15
You were doing fine till you tried to square both sides of 0 = x - 8√x +15. Squaring both sides won't get rid of the radical if you do the algebra right. Best to write it as 8√x = x+15 first. Now square both sides.
OHHHHH That make sense!
thanks!
HerroFish said:
the first one
It's more a problem of leaving out or of misplacing parentheses.
Writing , √(x-7) / ( √(x) -2 ) = √2 would be OK .
HerroFish said:
the first one
Square toot signs are not the issue; brackets are what you missed. Everything would have been clear if you had written (√(x-7)) / (√(x) - 2) = √2 . The point is that writing something like A/B-C means (A/B) - C if you read it using standard priority rules for mathematical expressions. If you want A/(B-C), you need brackets.
RGV
