Equations of circles tangent to graph
The discussion revolves around finding the equations of two circles that are tangent to the graph of the equation y² = 4x at the point (1, 2). The circles have a radius of 3√2, and participants are exploring the geometric relationships involved in this problem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the derivative of the graph to find the slope of the tangent line at the point of tangency. There are attempts to derive the equations of the circles based on the tangent line's properties and the relationship between the circles and the tangent line.
Some participants have made progress by calculating the slope of the tangent line and the equation of the tangent. There is ongoing exploration of how to find the centers of the circles based on the perpendicular relationship to the tangent line and the specified radius. Guidance has been offered regarding the use of distance formulas and the properties of special triangles.
Participants are working under the constraints of the problem, including the requirement that the circles must be tangent to the curve at a specific point and the radius of the circles. There is also a focus on the geometric relationships between the tangent line and the circles.
emma3001
Two circles of radius 3√2 are tangent to the the graph y^2 =4x at (1,2). Find the equation of each circle.
I have found the derivative of the graph, which is 1/√x. I know that the equation of the circle is X^2 + Y^2=r^2 where r is the radius so the equation of each circle is X^2 + Y^2=18. That is all I can get. Please help!
Okay, what is that at (1, 2)?
No, you don't know that. That is the equation of a circle with center at (0,0) and one thing you can be pretty sure of is that these circles do NOT have center at (0,0)!
If you have found the derivative at (1, 2) then you know the slope of the tangent line. What is the slope of, and what is the equation of, the line through (1, 2) perpendicular to the tangent line? I ask that because a tangent to a circle is always perpendicular to a radius. The centers of your two tangent circles must lie on the line through (1, 2) perpendicular to the tangent line to the curve, at distance 3\sqrt{2}.
okay so i have made progress...
I plugged in x=1 into the derivative so the slope of my tangent is 1. Then I found the equation of the tangent which is y=x + 1. I now know that the slope of my circles is -1 and I know that
(x-a)^2 + (y-b)^2= 18
Could you help me with the next step? In other words, how do I find a point with that slope and a distance or radius of 3sqrt2?
The slope of the circles is not -1; this is the slope of the line perpendicular to the tangent.
Once you've found the equation of this perpendicular line...
The cool thing is that the slope of the perpendicular line is -1 so the change in the x and change in the y are the same. Hint: If you draw a triangle you will see that it is a special triangle. From here, solve for the side(s) of that triangle.
Once you've done that, just simply add/subtract to (1,2) and you will get the centers of both circles. Finally, solve for the equation of the circles.
i know that my equation of the line perpendicular to the tangent is y=3-x. From that, do I use my distance formula to get the centre of the circle... before it said something about special triangles- could you elaborate?
The centers of your two circles, (a, b), are ON the line y= 3- x, so you know b= 3- a. Further, they are distance 3\sqrt{2} from (1, 2). The distance from (a,b) to (1, 2) is \sqrt{(a-1)^2+ (b-2)^2}= \sqrt{(a-1)^2+ (3-a-2)^2}
Set that equal to 3\sqrt{2} and solve for a.
