Why does the equipartition theorem depend on the number of degrees of freedom?
  • Thread starter Thread starter aaaa202
    Energy
The discussion centers on the equipartition theorem and its implications for temperature and degrees of freedom in a system. It explores why a system with fewer degrees of freedom becomes more willing to give up energy compared to one with many degrees of freedom when subjected to the same energy input. The analogy of restaurants illustrates how energy spreads across degrees of freedom, emphasizing that statistical configurations favor energy distribution. Additionally, temperature is clarified as not merely a measure of energy willingness but also influenced by factors like density and specific heat. Overall, the conversation highlights the statistical nature of energy distribution and its relationship to temperature and entropy.
aaaa202
I'm not sure that I understand the equipartition theorem intuitively. In general the thermal energy for a body is:
U = Nf/2kT
So more degrees of freedom, means that the temperature raises less for a fixed energy input:
dU = N f/2 k dT
Now temperature is a measure of an objects willingness to give up energy. Why would this depend on how many degrees of freedom a system has. I.e. why would a system with only one degree of freedom receiving a fixed amount of energy get more willing to give up this energy than a system with 100 degrees of freedom receiving the same amount of energy?
This might be a stupid analogy, but imagine two restaurants. A has 10 tables, and B has 20 tables. Now, assume a group of 60 people go to lunch at these two restaurants. Now these people don't like to sit together at a table, so they tend to spread evenly. Then in thermal equilibrium, you expect 20 people at restaurant A and 40 at restaurant B.
Of course, people represent units of energy, and tables are degrees of freedom, and temperature is the average amount of energy in a degree of freedom.
Why make the stipulation that units of energy do not like to sit together? It comes down to statistics. There are more configurations where energy is mostly spread out than with energy bunched up in one place.
U = Nf/2kT
dU = N f/2 k dT
Temperature is not a measure of the willingness to give up energy. Standing in 0 degree air, you do not give up as much energy as standing in 0 degree water. The difference is density and specific heats. A block of aluminum at 0 degrees doesn't feel as cold as a block of iron at 0 degrees.
I think the question you want to ask is why does adding a certain amount of energy to a 1 DOF material raise the temperature more than adding that same energy to a 100 DOF material. Its because that energy will spread evenly over those 100 DOF's. It spreads because of statistics, not by some spreading force. If you shuffle a deck of cards, the red suits and the black suits will spread more or less evenly throughout the deck.
Actually, I rather like the definition of temperature as the willingness to give up energy. That's actually a pretty intuitive translation of the more rigorous but abstruse definition:
\frac{1}{T}=\frac{dS}{dU}
The second law of thermodynamics says that entropy increases with time, so an increase of entropy with energy can be thought of as a willingness to grab energy from the surroundings. And this is equated to reciprocol of temperature. So higher inverse temperature means a higher willingness to grab energy from the surroundings. In other words, lower temperature is a stronger willingness to grab energy from things with higher temperature.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
