Equivalence of msd and velocity autocorrelation
The discussion focuses on the relationship between mean squared displacement (MSD) and velocity autocorrelation functions in particle ensembles, emphasizing their connection to the diffusion constant. A participant seeks a mathematical derivation linking these two concepts and raises questions about averaging over time origins and specific calculations related to the velocity autocorrelation function. They express difficulty in replicating a mathematical step involving time variables and seek a more straightforward explanation without advanced concepts like Fourier transforms or Maxwell-Boltzmann distributions. The conversation highlights the need for clearer connections between the two measures in a more accessible manner.
SchroedingersLion
Greetings,
I am searching for an explanation that connects the mean squared displacement in an ensemble of particles to the velocity autocorrelation functions. I know that they are connected since both of them can be used to calculate the diffusion constant. But I do not find a mathematical derivation. Does anyone have some link or material here?
SL
I have found the following sheet:
(source: https://nanohub.org/resources/7581/download/Martini_L9_DynamicProperties.pdf )
First question: What does it mean to average "over time origins"?
In my simulation, I calculate the msd via averaging over particle trajectories, not different time origins.
Second question: What exactly happens in the last step? I can't replicate it, if I rewrite t' in terms of TAU and t''.
From the second line, I write ## t'=t'' - \tau ##.
I get ##\int_0^t \, dt'' (- \int_{t''}^{t''-t} \, d\tau <v(t''-\tau)v(t'')>) = \int_0^t \, dt'' \int_{t''-t}^{t''} \, d\tau <v(t''-\tau)v(t'')>##
But that's not the same, is it?
I'm not sure how to best answer- there are lots of online materials that work through it, but let's just start with the Fourier-transformed position x(ω) = v(ω)/iω. Then, <[Δx(t)]2> = <v2>t2. Note, <v2 is not the same as the velocity autocorrelation function: for a Maxwell-Boltzmann distribution at temperature T,
<v(t)v(t')> = (v02-T/m)e-γ(t+t')+T/m e-γ|t-t'|
and
<[x(t)-x(t')]2>=##<[\int_{t'}^t \, dt_1 v(t_1) ]^2>##
Does that help?
and
Does that help?
Thank you, but not really... I would like to understand it without Fourier or Maxwell Boltzmann, as it should be a more trivial connection, see my calculation above.
  • · Replies 20 ·
