- 37,016
- 16,026
I don't know the metric for a moving evaporating black hole. Do you have a reference?jartsa said:Now when asked the observer says: "that moving black hole will be evaporated after two million seconds"
Is that right or wrong?
DaleSpam said:I don't know the metric for a moving evaporating black hole. Do you have a reference?
Reference?jartsa said:It's Minkowski metric, I guess.:)
No I don't have a reference.DaleSpam said:Reference?
I have already demonstrated that conclusion to be false for the Schwarzschild metric.jartsa said:Put one alarm clock near a black hole, another alarm clock far away from the black hole, set the clocks so that they go off at the same time. Move around at great speed, then note that alarms still go off at the same time. Conclude that kinetic and gravitational time dilations seem to be separate in this case.
I'm trying to find a scenario where a dummy like me can not easily see what the total time dilation is.DaleSpam said:Frankly, your conclusion seems completely unrelated to the proposed scenario. In order to conclude something you have to set up a scenario where different values of the thing being tested will change the outcome.
jartsa said:Why is this so simple?
Ok, here's a point where I seem to be misguided.DaleSpam said:Then, you want to determine the total time dilation as a function of U and V, ##\gamma(U,V)##. If you find that ##\gamma(U,V)=f(U) g(V)## for some functions f and g, then you say that the gravitational and kinematic time dilation are separate.
Since we already know ##\gamma(U,V)## cannot be expressed as ##f(U) g(V)## (except to a very crude 0-order approximation) you simply cannot get such an experimental result without violating GR and/or the Schwarzschild metric.
Ich said:Ok, here's a point where I seem to be misguided.
In my book, in a static spacetime, the time T of a canonical (=static) observer is exactly coordinate time, up to a factor $$\sqrt{g_{tt}}$$. That difference would count as of gravitational origin ##f(U)##. Now this observer observes something moving and find its time ##\tau## to be dilated by a factor ##\sqrt{1-v^2}##, if v denotes the velocity in said observers frame. So we have ##d\tau/dt = dT/dt d\tau/dT = \sqrt{1-2U}\sqrt{1-v^2}##, that is ##\gamma(U,V)=f(U) g(V)##.
To check my line of thought, I calculated your example on Wikipedia. There is one problem with it, what they sell as the Schwarzschild metric is obviously just a usual approximation to it. But their formula for the combined time dilation due to gravitational potential and coordinate velocity seems to be correct - because if you re-write it in terms of observed velocity, you find ##d\tau/dt = \sqrt{1-2U}\sqrt{1-v^2}##, with clearly separable gravitational and velocity components. That is, I found this to be the case, which might be an example of wishful thinking. I'd appreciate if you could check the result.
So for me, in a static spacetime, time dilation is a two-step thing: from coordinate to observer, then from observer to object. The first step is gravitational, the second needs SR only.
But I don't exclude the possibility that I just overlooked something important.
Yes, that was something I disagreed with, too. Where did you get this formula? To me, it looks like a very special kind of approximation (not eliminating the square root, that is).DaleSpam said:Let's keep things simple using c=1, and considering only objects with no radial component of velocity. So the Schwarzschild metric time dilation formula is:
##\gamma(U,V)=\sqrt{1-2U-v^2}##. Now, if ##f(U)=\sqrt{1-2U}## and ##g(v)=\sqrt{1-v^2}## then ##f(U)\;g(v) = \sqrt{1-2U-v^2+2Uv^2} \ne \gamma(U,V)##
I disagree. You have total time dilation ##1/\gamma##, which cosists of two factors. The first is ##\sqrt{g_{tt}}##, definitely GR.The second is really SR time dilation and nothing else. Of course, in Schwarzschild coordinates or something, you have to cut it out of the "gravitationally contaminated" coordinates - using ##f(U)##. But this step is physically nothing else than the measurement of local time dilation. Mathematically, it is the dot product of two four velocities at the same event. Both are clearly nothig else than SR time dilation, with no contribution of the potential at all. We could do this anywhere in every universe at every place. It's jut the introduction of certain coordinates that make g(U,v) a function of U. It isn't, really. It's g(v) only, if v is a proper local velocity.DaleSpam said:You can, as you describe, build a local inertial frame around any event on the worldline of an observer down in a gravity well. In that local inertial frame the observer can serve as a local "reference clock" and attribute any measured time dilation at very nearby events entirely to kinematic time dilation. However, that still does not generally lead to a separation between the gravitational and kinematic time dilation since the "reference clock" is already gravitationally time dilated. In other words, you can use this method to construct a valid ##f(U)##, but then you are left with ##g(U,v)## since the v is measured wrt a local "reference clock" which is itself a function of U.
Ich said:Mathematically, it is the dot product of two four velocities at the same event.
PeterDonis said:But then what do you call the fact that, for example, an observer at rest in a gravity well can exchange light signals with an observer at rest far away from the gravity well ("at rest" means they are at rest relative to each other) and verify that his elapsed proper time between two successive round-trip light signals is shorter than the far-away observer's elapsed proper time between those round-trip light signals? The standard name for that is "gravitational time dilation", and it is certainly not just a matter of the dot product of two 4-velocities at the same event.
I put radioactive gas in a bottle, in another bottle I put radioactive gas which decays twice as fast as the first gas. Then I heat the second gas until the gases decay at the same rate.PeterDonis said:Because you only varied the velocity (you put one clock into a carousel), not the altitude
I got the formula from the Wikipedia site I linked to, with c=1 and the radial component of velocity = 0 for simplification, as I mentioned earlier. We can keep the radial velocity if you want, but it makes the gravitational and kinematic components even less separable.Ich said:Yes, that was something I disagreed with, too. Where did you get this formula?
That is just the problem. It doesn't consist of two factors. This doesn't take a long involved chain of physical reasoning, just note that ##\gamma(U,v) \ne f(U) \, g(v)##. The factors simply don't exist.Ich said:I disagree You have total time dilation ##1/\gamma##, which cosists of two factors. The first is ##\sqrt{g-{tt}}##, definitely GR.The second is really SR time dilation and nothing else.
The equivalence principle does apply, but why should that be at all related to separating out SR and GR components? The requirement is that the two different frames agree on the measurements, not that either be able to separate time dilation into different components.atyy said:Or is it that the equivalence principle does apply - but in which case how does one separate out the SR and GR components?
atyy said:I am still confused what the reply to the OP is.
atyy said:Is it that the equivalence principle doesn't apply, because one integrates over a path in spacetime, which is nonlocal so the equivalence principle doesn't apply?
DaleSpam said:The equivalence principle does apply
DaleSpam said:The equivalence principle does apply, but why should that be at all related to separating out SR and GR components? The requirement is that the two different frames agree on the measurements, not that either be able to separate time dilation into different components.
jartsa said:I have varied velocity by heating, and altitude by dipping.
jartsa said:Has one gas decayed more than the other after this procedure?
PeterDonis said:In the example given in the Usenet Physics FAQ, the EP applies just fine, because the experiment can be analyzed within a single local inertial frame. The fact that you also get gravitational time dilation between observers whose difference in height is too large for them to both fit in a single local inertial frame is just an additional fact; it doesn't change the analysis of the case where the height difference is not too large.
It's just how you calculate the kinematic time dilation of two observers at the same event. The SR part of time dilation, if you like.PeterDonis said:If this is your definition of "time dilation", then there is no such thing as gravitational time dilation to begin with.
Ah, I see. But they use the coordinate velocity dx/dt. The decomposition is in terms of relative velocity to the local static observer. If I'm not mistaken, that is ##v=v_{rel} =v_{co}/ \sqrt{1-2U}##. So you haveDaleSpam said:I got the formula from the Wikipedia site I linked to, with c=1 and the radial component of velocity = 0 for simplification, as I mentioned earlier.
It's just more math, but with ##v_{r, rel} =v_{r,co}/ (1-2U)## you still get ##\sqrt{1-2U}\sqrt{1-v^2}##.DaleSpam said:We can keep the radial velocity if you want, but it makes the gravitational and kinematic components even less separable.
Sure, I agree, but as I said earlier ##v_{co}=g(U,v)\ne g(v)##. I.e. different observers at different U will disagree on the value of ##v_{co}##.Ich said:Ah, I see. But they use the coordinate velocity dx/dt. The decomposition is in terms of relative velocity to the local static observer. If I'm not mistaken, that is ##v=v_{rel} =v_{co}/ \sqrt{1-2U}##. So you have
##\sqrt{1-2U-v_{co}^2}=\sqrt{1-2U-(1-2U)v^2}=\sqrt{1-2U}\sqrt{1-v^2}##
Sorry, I can't follow. I don't see why a decomposition should use, of all things, a coordinate velocity.DaleSpam said:Sure, I agree, but as I said earlier ##v_{co}=g(U,v)\ne g(v)##. I.e. different observers at different U will disagree on the value of ##v_{co}##.
I think that the OP's idea for involving the equivalence principle is that the centrifugal acceleration felt by the muon in the storage ring should be equivalent to a gravitational field and produce gravitational time dilation in the muon's frame. The muon's frame is a little bit of an unusual frame since it has the Coriolis acceleration as well as the more normal centrifugal acceleration, but for a lab clock at the center is at rest in the rotating frame, so for that specific scenario you can make a gravitational analogy where the muon is dilated because it is deep in a "gravitational potential" (from the centrifugal force).atyy said:I do understand the two frames will agree on the measurements, but how does that involve the equivalence principle?
Because time dilation is a comparison of proper time to coordinate time, so naturally the velocity should be the coordinate velocity of the same coordinate system for which the coordinate time is being used.Ich said:Sorry, I can't follow. I don't see why a decomposition should use, of all things, a coordinate velocity.
Not for any ##\gamma(U,v)## of which I am aware. Again, if you don't like the one I am using can you post the one you are thinking of? There may very well be some, but I have never seen a separable one.Ich said:The thing is: ##\gamma(U,v)= f(U) \, g(v)##. f is a function of the potential only, and g is a function of the relative velocity only.
There is no such thing as frame-independent time dilation.Ich said:That is a geometric, frame-independent, unique decomposition of time dilation, exactly what you've been looking for.
I have never seen anyone do this, so I am not sure. However, it does sound interesting. What do you mean by "reference Killing vector"?Ich said:Ok, for the geometric formulation you need the Killing vector and the four velocity at the event in question, and also a reference Killing vector. The ratio of the lengths of the Killing vectors gives gravitational time dilation, the product of the normalized Killing vektor with the four velocity gives kinematic time dilation. Is this right?
atyy said:(1) how is going round in a ring "local"
atyy said:(2) in the muon case one observer is inertial and one is accelerating, whereas the spaceship example has both observers accelerating.
Ok, but see my answer to your third reply. In my opinion, the coordinate time is relevant only if is connected with something physically interesting.DaleSpam said:Because time dilation is a comparison of proper time to coordinate time, so naturally the velocity should be the coordinate velocity of the same coordinate system for which the coordinate time is being used.
There seem to be misunderstandings. I used exactly the one(s) you used also. I just replaced the coordinate velocity with the relative velocity. The expressions then reduce neatly to the one given by me.DaleSpam said:Not for any ##\gamma(U,v)## of which I am aware. Again, if you don't like the one I am using can you post the one you are thinking of? There may very well be some, but I have never seen a separable one.
If we're talking about static spacetimes, there are the canonical static observers. Their common simultaneity planes are frame independent objects and define gravitational time dilation. Of course, that's the same as Schwarzschild coordinate time, but I think we call the effect time dilation because these coordinates represent the underlying frame-independent preferred observers. If the coordinates were "just numbers" - as they may well be -, you wouldn't call their relation to proper time "time dilation", as it'd be completely arbitrary.DaleSpam said:There is no such thing as frame-independent time dilation.
I'm making this up as I go along, that's why I ask you to follow and see if it is right.DaleSpam said:]I have never seen anyone do this, so I am not sure. However, it does sound interesting. What do you mean by "reference Killing vector"?
