Estimate its capacitance to earth
To estimate the capacitance of a telephone wire suspended 10m above the ground, the mirroring method is recommended rather than the cylindrical capacitor formula, which yielded an incorrect answer. The discussion suggests considering two parallel wires with opposite charges to simplify the problem, maintaining the same electric field. Participants express confusion over the correct approach and seek clarification on applying the mirroring method effectively. The conversation highlights the importance of understanding different methods for calculating capacitance in this context. Overall, the mirroring method is emphasized as the appropriate technique for this scenario.
Ripperbat
A telephone wire of diameter 1mm is suspended 10m above the ground. Estimate its capacitance to Earth per unit length
I've tried to solve the problem by using the formula for a cylindrical capacitor and got the answer but apparently it was wrong. Instead it's supposed to be solved by the mirroing method. So now I'm lost. Help me please :)
Thx
Thx
Consider two parallel 1mm thick wires a distance 20m apart with opposite charges, same electric field for the above problem. Does that make things easier? I'm not sure.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
