Estimating spring coeff and damping coeffient of my car
  • Context: Undergrad
  • Thread starter Thread starter zacharoni16
    Car Damping Spring
The discussion revolves around estimating the spring constant and damping coefficient for a 1994 Nissan Pathfinder SUV using practical methods. Participants explore theoretical and experimental approaches to apply the quarter-car model in their project.
  • Homework-related
  • One participant suggests using Hooke's law by measuring the ride height of the car without load and then with a 200-pound weight to estimate the spring constant.
  • Another participant proposes an alternative method of jacking up the car until a tire lifts off the ground to measure displacement, arguing this utilizes the car's weight effectively.
  • There is a discussion about whether to use the full weight of the car or a quarter of it for calculations, with some participants agreeing that using a quarter is reasonable given the weight distribution.
  • For estimating damping, one participant mentions the possibility of bouncing the suspension by hand and counting oscillations, while another suggests using video analysis to measure oscillation time and displacement.
  • Clarification is sought on whether half-cycles refer to the upward movements of the car during oscillation.
Participants generally agree on the methods to estimate the spring constant and damping coefficient, but there are varying opinions on the specifics of weight distribution and the definition of half-cycles in oscillation measurement. The discussion remains unresolved regarding the best approach to take.
Participants express uncertainty about the weight distribution between the front and rear wheels, and there are limitations in the tools available for conducting drop tests or precise measurements.
zacharoni16
I'm working on a project, I just need ballpark estimates for the spring constant and damping coefficient for my 1994 Nissan Pathfinder SUV.
I was thinking of using Hookes law to estimate the spring constant, can I just measure the ride height of the car with nothing in it, then add 200 pounds of weights in the back and measure the displacement from the reference to get the spring constant?
For the damping, I know most cars are near critical damped right? to make oscillations die out fastest.
I'm using the quarter-car model for my project and I just need to estimate these two parameters on a real car
Any advice or suggestions would be awesome. I know damping they used to do a drop test and watch the oscillation for a "shock" test but I don't have the tools or a jack to safely do this
That's a good idea, but I would forget about the 200 pounds weight. Jack up the car, and see how far you have to raise the car body before a tire lifts off the ground. That way, you will be using the weight of the car "for free".
You can get a rough idea by just "bouncing" the suspension by hand, and counting how many half-cycles the body moves before it stops. The oscillations will be fairly slow, so you could video them with a cellphone or digital camera and then measure the images frame by frame to get a graph of the displacement agaisnt time. Then try to make your spring-mass-damper model match what you measured.
So you mark a reference point, jack the car up until the tire barely lifts off the ground, that distance from the reference is the displacement, and I use the car weight as the force as listed in the owners manual? Or would I use 1/4 of the weight since its one tire?
Correct. The weight might not be split 50/50 between the front and rear wheels, but if you don't know the CG position of the car that's a reasonable assumption.
Thank you!
For the damping, the half-cycles would be the peak to peak every time it comes "up" correct?
If I video tape it I will just need to know the FPS of the camera to get a time scale like they do on myth busters?
Confused :/ any help thank you AlephZero
If I count every time the car goes above the ride height that is a half sine (half of a cycle) ??
  • · Replies 131 ·
9K
