Estimation of the Power Output of a steam turbine
To estimate the steam required for electrical power generation using a steam turbine, one must consider the energy content of the steam and the turbine's efficiency, following the conservation of energy principle. The basic formula is Eout = Ein * Efficiency, where specific parameters like pressure, temperature, and mass flow rates of steam must be defined. For practical calculations, it's essential to consult tables of steam properties and consider the effects of re-heating in multi-stage turbines. The duration a boiler can continuously supply steam to a turbine generator set depends on the fuel supply rather than a fixed time limit. Recommended resources for further study include introductory thermodynamics textbooks and online materials focused on steam turbine thermodynamics.
Chandrakanth_balusa
Hoow can one estimate the amount of steam required to generate certain amount of electical power mathematicaly?
Broad answer to broad question: From the energy content of the steam and the efficiency of the turbine.
Hello Russ Watters,
thanks for your response!
do u have any mathematical formulae concernig my question?
regards
Balusa
Again, the question is very broad, so the response is a basic conservation of energy statement:
If what you really want to know is the details of how a turbine works, I suggest starting with some of your own reading and then asking specific questions about that.
Likes Chandrakanth_balusa
What you need is not a formula, but rather a table of the properties of water and steam. Such tables are easy to find on the Internet.
Take the energy of the steam coming into the turbine, minus the energy of the steam coming out. As a first approximation, assume 100% efficiency and neglect other secondary factors.
But you must specify the pressure, temperature, and mass flow of steam coming in, and the pressure, temperature, and (presumably the same) mass flow coming out of the turbine.
If the steam is re-heated, then you can use the same procedure to separately calculate the powers of the high pressure turbine and the intermetiade/low pressure turbines.
Likes Chandrakanth_balusa and russ_watters
to be specific , I have some knowledge of how the turbine generators sets work in a steam power plant.
i have seen some threads regarding the calculation of turbine output power.
but i wanted to know if there is any possibility to estimate if how long a boiler can serve particular turbine generator set to produce power continously depending on the steam available,
if possible can anyone suggest me a nice platform or books regarding steam turbines with calculations and some examples!
but i wanted to know if there is any possibility to estimate if how long a boiler can serve particular turbine generator set to produce power continously depending on the steam available...
That's an oddly worded question. There should not be a "how long" or rather the answer is: as long as you keep providing it with fuel.
...if possible can anyone suggest me a nice platform or books regarding steam turbines with calculations and some examples!
Any introductory thermodynamics book will put considerable emphasis on this. I keep the textbook by Cengel and Boles at my desk (for HVAC).
There's lots of online resources that look good too, googling "steam turbine thermodynamics".
ok thank you for valuable responses.
I will come back again with few question after gaining some knowledge of steam turbines.
See Fundamentals of Engineering Thermodynanics by Moran et al.
  • · Replies 22 ·
