Euclide's Algorithm to Calculate GCD
  • Thread starter Thread starter lcam2
    Algorithm Gcd
Euclid's algorithm is used to calculate the GCD of two integers by repeatedly finding the remainder until it reaches zero. The provided code attempts to implement this but fails to correctly track the last non-zero remainder. To fix this, the code should use a loop that continues until one of the integers becomes zero, while updating the other integer as the GCD. The final output should be the non-zero integer when the loop ends. Properly implementing this logic will yield the correct GCD result.
lcam2
Using Euclid's algorithm write a program with a function that determines and returns the GCD of two integer arguments.
This is what i wrote, when i print the remainder is zero, How can i get the last remaninder before the zero value? :confused:
Thanks
#include <iostream>
using namespace std;
void remainder ( int, int); //Function Prototype
int main ()
int a, b;
cout << "This Program calculates the GCD of two integers \n"
<< "Please enter two integers" << endl;
cin >> a >> b;
remainder (a, b); //Calling the Function
return 0;
void remainder ( int a, int b) //Remainder function
int x, remainder;
remainder = 0;
int r;
if (a > b)
{r = b;
r %= b;
else
{r = a;
r %= b;
cout << r << endl;
You need to repeat the process until the remainder is zero and then output the other variable. For example, something like the following code should output gcd(a,b) correctly.
Code:
int r;
if (a > b)
  { r = a;
    a = b;
    b = r
  }while (a !=0)
  { r = a;
    a = b % a;
    b = r
cout << b << endl;
