Are Euler-Lagrange Equations Applicable to All Differential Manifolds?
  • Thread starter Thread starter Incand
    Euler-lagrange
Incand
Hey!
I'm not sure if this belongs better here or in mechanics but while I was doing some mechanics problems I started wondering if Lagrange equations are true for any differential manifold.
Obviously they work for pseudo-riemann ones (general relativity) but do they work for others (all)?
I got no real knowledge of the math behind at all just wondered, since they work for relativistic particles, in what geometry they do and don't work.
Lagrange's equations are a local thing, so yes, because locally, in a manifold, it's no different from R^n. Actually, the configuration spaces you see in mechanics tend to be manifolds, so you're presumably already using the fact that they work in manifolds. You don't necessarily care about the geometry, unless that feeds into the Lagrangian somehow (generally, it will, but not always). It all just depends on having local coordinate systems, and that precedes the geometry.
Likes Incand
Thanks, very well explained!
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
