(Eulerian) Velocity of an elementary vector
The discussion focuses on defining the Eulerian rate deformation tensor by expressing the time derivative of an elementary vector in terms of gradient velocity. The equation presented suggests that the time derivative of a vector can be expressed as a difference in velocity at two points, leading to confusion about its physical interpretation. Participants clarify the material time derivative of a vector field, emphasizing the distinction between time dependence and spatial movement of fluid elements. There is a debate over the notation used and the absence of a velocity gradient in the material derivative of the elementary vector. Overall, the conversation highlights the complexities in understanding Eulerian descriptions in fluid dynamics.
trabo
Hello everyone,
In order to define the eulerian rate deformation tensor, one should first express \dfrac{d}{dt}(\underline{dx}) in gradient velocity terms (denoted \underline{\nabla v} with v equal to the partial time derivative of the geometrical mapping that relates the inital configuration to the current one).
In an article, we claim that
\dfrac{d}{dt}(\underline{dx})=v(\underline{x}+\underline{dx},t)-v(\underline{x},t) (1)​
and thus
\dfrac{d}{dt}(\underline{dx})=\underline{\nabla v} . \underline{dx}​
I'm not sure about (1). It says actually that
\dfrac{d}{dt}(\underline{x} +\underline{dx}-\underline{x}) =\dfrac{d}{dt}(\underline{x} +\underline{dx})-\dfrac{d}{dt}(\underline{x} )​
I can't see that clearly though. Is there any physical explanation ? May be an approximation since we're dealing with elementary vectors...
Regards.
The material time derivative of an arbitrari vector field is derived as follows: In a little time increment \mathrm{d}t on the one hand the vector field changes due to its own time dependence, \mathrm{d} t \partial_t \vec{A}. On the other hand, the fluid element that was at position \vec{x} at time t, will have moved by \mathrm{d} \vec{x}=\mathrm{d}t \vec{v}. So the material time derivative is given by
\mathrm{D}_t \vec{A}=\partial_t \vec{A}+(\vec{v}\cdot \nabla)\vec{A}.
Thanks for the reply.
The expression that I know for the material derivative of a vector (and in general a tensor of any order) \vec{A} is
D_t \vec{A} = \dfrac{\partial \vec{A}}{ \partial t} + \nabla \vec{A} .\underline{v}​
Anyhow, a way of seing the equality is :
\dfrac{d}{dt} (dx)=dv​
that is adimitting that
\dfrac{d}{dt dv} (dx)=\dfrac{d^2 x}{dt dv}=\dfrac{d}{dv}\Big ( \dfrac{dx}{dt}\Big) =1​
but I can't tell why is it peculiar to the eulerian description.
I'm not so sure what your notation in the 2nd term of the material time derivative should mean. As derived in my previous posting, the correct expression in usual nabla-calculus notation is
\mathrm{D}_t \vec{A}=\partial_t \vec{A} + (\vec{v} \cdot \vec{\nabla}) \vec{A}.
In component-Ricci calculus notation, including Einstein-summation notation and strictly distinguishing co- and contravariant components (which is very useful also for Cartesian components as here!) what's meant is
(\mathrm{D}_t A^{j})=\partial_t A^j + v^k \partial_k A^j.
Note that
\partial_k = \frac{\partial}{\partial x^k}.
Yes this is what I meant too, it was just a matter of notation. But as you notice, there is no velocity gradient in the material derivative of dx, whereas it is stated that \dfrac{d}{dt} (dx)=\nabla v . dx
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
