Evaluate the integral (inverse trig)
  • Thread starter Thread starter shft600
    Integral Trig
7 replies · 2K views
shft600
Evaluate the following integral:
(int)1/sqrt(2x-x2)dx
d(arcsinx)/dx = 1/sqrt(1-x2)
I just need a good start in the right direction on this one so I can at least try it. I know the arcsin d/dx as above, but how do I make this work? Is it some kind of integration by parts or reduction? I have no idea how to go about dealing with the sqrt(2x-x2) mostly, or how it would get there from arcsin...
any help you can give would be much appreciated!
hm.. I'm trying that but still stuck, I get
int: 1/sqrt(x(2-x))dx, I can move the root up to the top easily enough by multiplying by sqrt(x(2-x))/sqrt(x(2-x)), but that doesn't help much. I found the formula relating a/sqrt(b+x2) to (a/sqrt(b))arctan(x/sqrt(b))+C, but that still doesn't help me with the 2x...
No no. -x^2 + 2x = -(x^2 - 2x) = -(ax + b)^2 + c. Find a, b, and c.
Once you do that, what happens if you let u = ax + b?
by that, it should be
-(x2-2x) = -((x-1)2-1), or a=1, b=-1, c=-1
so then, making u=x-1, du=1, it becomes
int{ du/sqrt(-u2-a2)
and that falls into the arccosh formula as:
cosh-1(-u/a)+c
or
cosh-1(-(x-1)/1)+c
cosh-1(1-x)+c, and that should be the final answer for the indefinate integral right? or can I just plug the -u in like that?
cosh-1(-u/a)+c
or
cosh-1(-(x-1)/1)+c
Be careful. You are saying -(x-1)^2 - 1 = 2x - x^2?
What if x = 1? Then, -1 = 2 - 1 = 1, which is wrong. It should be -(x-1)^2 + 1.
So if we let u = x - 1
So, we have,
[tex] \int \frac{1}{\sqrt{1 - u^2}} du[/tex]
That should look more familiar.
