Evaluating complex integral problem
The discussion revolves around evaluating the integral $$\int^\infty_{-\infty} \frac{\sqrt{2a}}{\sqrt{\pi}}e^{-2ax^2}e^{-ikx}dx$$, where a and k are positive constants. Participants are exploring techniques related to complex integrals and their applications in quantum mechanics, specifically in the context of overlap integrals and probability calculations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of standard integral results and consider substitutions to simplify the integral. There are attempts to relate the integral to known forms, and some participants question the correctness of their algebraic manipulations and substitutions.
There is an ongoing exploration of different methods to evaluate the integral, with some participants suggesting substitutions and others expressing uncertainty about their previous attempts. Guidance has been offered regarding the need for consistent substitution throughout the integral.
Participants are working within the constraints of an assignment that requires the use of specific wave functions and integral results provided in the problem statement. There is a focus on ensuring the correct application of mathematical techniques in the context of quantum mechanics.
Leechie
I'm having some trouble evaluating the integral
Where a and k are positive constants
I've been given the following integral results which may be of help
$$\int^\infty_{-\infty} e^{-x^2} dx= \sqrt{\pi}$$$$\int^\infty_{-\infty} e^{-x^2}e^{-ikx} dx = \sqrt{\pi}e^{-\frac{k^2}{4}}$$
The best I can come up with is
$$\int^\infty_{-\infty} \frac{\sqrt{2a}}{\sqrt{\pi}}e^{-2ax^2}e^{-ikx}dx=\sqrt{2a}e^{-\frac{k^2}{8a}}$$
But I'm not sure this is correct. Would someone be able to explain the steps to take to evaluate this integral so I can attempt to work it out myself. Thanks.
Are you talking about using those standard integrals you've posted? Or do you want to derive those standard integrals?
In the first case, it's just a simple substitution, isn't it?
In terms of the answer, I think that factor of ##\sqrt{2a}## should have canceled out.
Sorry, I'll give you the full story. Its an assignment question in which I have to use the overlap rule to find the probability that a measurement of the particles energy will give the ground state. The given wave functions are:
$$Ψ(x,0)=\left(\frac{\sqrt{2a}}{\sqrt{\pi}}\right)^\frac{1}{4}e^{-ax^2}e^{-ikx}$$$$ψ(x)=\left(\frac{\sqrt{2a}}{\sqrt{\pi}}\right)^\frac{1}{4}e^{-ax^2}$$
The other integrals ##\int^{\infty}_{-\infty}e^{-x^2}dx=\sqrt{\pi}## and ##\int^{\infty}_{-\infty}e^{-x^2}e^{-ikx}dx=\sqrt{\pi}e^{-\frac{k^2}{4}}## where given in the question as integral values which may be useful.
The overlap integral I'm using is:
$$p=\left| \int^{\infty}_{-\infty}ψ^*(x)Ψ(x,0)dx \right|^2 $$
After substituting in the wave function values and simplifying a bit I've eventually ended up with:
$$p=\left| \frac{\sqrt{2a}}{\sqrt{\pi}} \int^{\infty}_{-\infty}e^{-2ax^2}e^{-ikx}dx \right|^2$$
Which is where I'm getting stuck.
I was thinking I need to do something to ##\int^{\infty}_{-\infty}e^{-2ax^2}e^{-ikx}dx## and get it into the form ##\int^{\infty}_{-\infty}e^{-x^2}e^{-ikx}dx##. I've tried completing the square and using substitution which is how I got to the answer ##\sqrt{2a}e^{-\frac{k^2}{8a}}## but I'm not confident I've done it right. Really I just need some help evaluating ##\int^{\infty}_{-\infty}e^{-2ax^2}e^{-ikx}dx##. Thanks.
Just do the substitution ##u = \sqrt{2a}x##.
I think you just made an algebraic error the first time.
By the way, when you have a parameter in a standard integral, ##k## in this case, it's best to replace that with a parameter you are not going to use in your working. E.g. Use ##\lambda## here.
That makes it easier than using ##k## for two different things.
Thanks for the tip!
I think this is where I'm getting confused. I thought the substitution ##u=\sqrt{2a}x## would mess the integral up and make it ##\frac{1}{\sqrt{2a}}\int^{\infty}_{-\infty}e^{-u^2}e^{-ikx} dx##?
Leechie said:
Thanks for the tip!
If you can't do integration then QM will be hard indeed. You must substitute ##u## all the way thru the integral. Just replacing ##x## in one place is no good.
Ok, thanks for your help with this.
  • · Replies 105 ·
12K
