Evaluating Complex Integrals Using Cauchy's Integral Formula
6 replies · 2K views
AlBell
Use Cauchy's integral formula to evaluate
when
a) C is the unit circle
b) c is the circle mod(Z)=2
I know the integral formula is
for the unit circle I was attempting F(z)=sin(z) and Z0=∏/2, which would give a solution of 2∏i, however if this is the correct method I am unsure how to modify it for a larger unit circle as I thought the final result was independent of radius
The integral formula requires the point z0 to be contained inside of the curve gamma that you are integrating around. Draw some pictures and you should see the difference between the two curves they are asking you to integrate on
Ah so the unit circle wouldn't actually contain the point pi/2 whereas the circle mod(z)=2 would?
That's right. So in the unit circle case you need to figure out something else that let's you calculate the integral
Can I then use the integral theorem that says it will equal 0?
I'm a bit confused again, sorry!
I thought that the z-Pi/2 on the denominator of the integral means we just shift the origin of the circle to a new position?
