Evaluating double integrals to find area
  • Thread starter Thread starter footboot
    Area Integrals
10 replies · 3K views · last reply
footboot
Find the area of the region R bounded by the parabola y = 2x2−2
and the line y = 2x + 2 by sketching R, and evaluating the area
integral
A = (doubleintegral) R dxdy.
i found the points of intersection which were -1 and 2 and sketched the region. but I am really stuck on evaluating it. If it was dydx i would have no problem but since its dydx i keep ending up with x's in my answer!
Welcome to PF!
Hi footboot! Welcome to PF! :smile:
(have an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
Show us exactly what you've done. :smile:​
im sorry its quite hard ot get used to writing maths on the internet!
The limits i used were 2 and -1 on the left integral and 2x+2 and 2x2 -2 on the right integral.
I integrated with respect to x which just gave x, then filled in the values and got
(2x+2)-(2x2-2) which gave -2x2 +2x +4
I then integrated with respect to y and filled in 2 and -1 for y but all the x's from the first parrt are still there so I get an answer of x2+x+10. Which is obviously not right as I presume the answer should have no variables in it?
Hi footboot! :smile:
oh i see now …
you've integrated in the wrong order!
integrate wrt y first, that gives you a function of x, then integrate wrt x and that gives you a number. :smile:
(alternatively, if you integrate wrt x first, you must do it between limits which are a function of y)
In the question it says dxdy so doesn't this mean i have to integrate wrt to x first? And if i do have to do it that way how would I find the limits as a function of y?
Thanks for your help!
Without seeing the exact question, it's difficult to say.
dxdy = dydx, and the order of integration doesn't matter, so you can do it either way.
However, of course, if the question insists on integrating wrt x first, then it's checking whether you know how to get the limits (which you don't, yet! :wink:), and of course you must do it that way.
So, what are the limits for x (they are functions of y) if you integrate wrt x first? :smile:
(in other words, for a fixed value of y, what are the limits of x?)
In lectures we have been doing examples of functions where dxdy is not equal to dydx so that's why i thought i couldn't do it here. I did integrate wrt y first anyway and came out with an answer of 9 which looks about right from the graph iv drawn.
By changing the limits for x did you mean change the original functions for the parabola and line? because I did that first and i came out with quite complicated terms for the limits! So I am really hoping 9 is right
Thanks for all your help!
footboot said:
… I did integrate wrt y first anyway and came out with an answer of 9 which looks about right from the graph iv drawn.
Unless you show what you've done, I can't say whether it's right. :redface:
I integrated wrt to y and got y, filled in 2x+2 and 2x2-2 into y and got -2x2 +2x +4. Then integrated with respect to x and got -2x3/3 + x2 + 4x. filled in 2 and -1 to this function and ended up with a value of 9. Which is hopefully right as iv been spending hours on this question! Also I was wondering I did a different
integration area question earlier and got a negative answer even though the function was above the x-axis would this indicate that I went wrong somewhere in the question?
Yes, that looks ok. :smile:
(if you got a negative area in another problem, then yes, that's obviously wrong …
I'd guess you got the two limits the wrong way round :wink:)
