Evaluating expression (numerical analysis)
blob84
Hello, using octave when I evaluate this expression (1+1/x)*x-x, with x = 10^(15) i get as result 1.125, I didn't undesrtood why,
I know that octave show 15 digits in format long so when i evaluate (1+1/x)*x i get 1e15, the last digit is not visible and it is 1, so when i do substraction i get 1.12500000000000.
Mathematics news on Phys.org
It is not my area of expertise but...
You are subtracting two nearly equal quantities from each other. This is a classical way to lose precision.
From what I can discover with a quick trip to Google, Octave works with double precision floating point representation. Likely this would be IEEE floating point. In this format, floating point numbers are expressed in binary with a 53 bit mantissa, an 11 bit exponent and a 1 bit sign for a total of 65 bits. This fits into an eight byte field because the leading bit in the mantissa is always 1 and need not be stored.
http://en.wikipedia.org/wiki/Double-precision_floating-point_format
10-50 is approximately equal to 1.125 * 2-50 add 1 and you get, in binary
1.00000000000000000000000000000000000000000000000001001 [54 bits]
If you hypothesize IEEE floating point with one guard bit, that would fit with a result of 1.125.
There are actually two classical flaws. One is in (1 + 1/x), which sums two values of vastly different magnitudes. Second is in the subtraction.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
