MHB What Are the Possible Values of 2^(-i)?
The discussion focuses on finding the possible values of 2^(-i) using complex logarithms. Participants explore the multivalued nature of logarithms, noting that 2 can be treated as a complex number, leading to infinite solutions. The expression 2^(-i) is rewritten as e^(-i(ln(2) + 2kπi)), emphasizing the role of the arbitrary integer k in generating multiple values. Additionally, the function f(z) = 2^z is discussed, highlighting that the number of solutions varies based on whether z is an integer, rational, or another complex number. The conversation concludes with an acknowledgment of the insights gained regarding complex exponentiation.
shen07
Find all possible Values of:
2(-i)
Re: Exercise
2(-i)
What have you tried so far?
-Dan
Re: Exercise
well i have tried using
uv=evln(u)
and get cos(ln(2))-isin(ln(2))
but is it the solution because i am asked to find all the possible values
Re: Exercise
uv=evln(u)
The logarithm is a multivalued function so
$$\log(a) = \ln|a|+iarg(a) $$
Re: Exercise
Yes i know that but here we have ln(2) and we can't write this in the above form.
Re: Exercise
$$2^{-i}=e^{-i\log(2)}=e^{-i(\ln|2|+2k\pi i)}$$
Re: Exercise
but should we not apply complex logarithm ,i.e LOG to complex numbers only, here we should have use LN as far as i have understand. Correct me if i am wrong
Re: Exercise
But 2 is still a complex number .
The function
$$e^{\log(2^{-i})}$$
is a multivalued function so it has infinite solutions .
Re: Exercise
The function
ok i understand what you are trying to say. 2 is also found in the complex plane, so we can apply this rule to it, hence obtaining several values with this arbitrary k.
Thanks
Re: Exercise
For more information consider the following
$$f(z)=2^{z}$$ where $z$ is any complex number .
  1. if $z$ is an integer then the function has only one solution
  2. if $z$ is a rational number then it has finite number of solutions .
  3. If $z$ is any other complex number then it has finitely many solutions .
Re: Exercise
Thanks a Lot for this Idea..Will remember it..:D
  • · Replies 35 ·
