Evaluating lim(x=>0) (x+9)^(1/2)-(x-9)^(1/2)/x
  • Thread starter Thread starter vrmuth
The limit evaluation of lim(x→0) ((x+9)^(1/2)-(x-9)^(1/2))/x is discussed, revealing that the limit does not exist due to the function's domain being restricted to [9, ∞). Participants suggest using L'Hôpital's Rule for evaluation, but it is noted that this method does not always apply. The discussion also highlights the importance of correctly identifying the domain and suggests using graphing tools for better understanding.
  • Understanding of limits in calculus
  • Familiarity with L'Hôpital's Rule
  • Knowledge of function domains
  • Basic algebraic manipulation skills
  • Study the applications of L'Hôpital's Rule in different limit scenarios
  • Learn about function domains and their implications in calculus
  • Explore algebraic techniques for evaluating limits without L'Hôpital's Rule
  • Utilize graphing calculators or software to visualize limits and function behavior
Students and educators in calculus, mathematicians exploring limit evaluations, and anyone interested in understanding the nuances of L'Hôpital's Rule and function domains.
vrmuth
i am also stuck with this one
lim(x=>0) ( (x+9)^(1/2)-(x-9)^(1/2))/x , i want to evaluate this algebraically,can anybody give me a clue
A couple of applications of l'hospital's rule will do it :)
hi jhamm thanks,could you please show how l'hospital's rule will do it , and cann't it be done algebraically?
As you have written it, the limit does not exist. Have you copied the question correctly?
The domain for the function \displaystyle f(x)=\frac{\sqrt{x+9}-\sqrt{x-9}}{x} is [9, ∞) .
So, as Hootenanny wrote, there appears to be something wrong with the problem as you posted it.
yes the limit does exist, thanks
Are you sure?
Let f(x) = g(x)/h(x).
Then:
lim f(x)
= lim [g(x)/h(x)]
= [lim g(x)] / [lim h(x)]
Harrisonized said:
Are you sure?
Then:
lim f(x)
= lim [g(x)/h(x)]
did you see the function and that x tends to 0 ? :)
Let lim g(x) = a, where a∈ℂ (that is, a is a complex variable / it admits complex values). Then lim a/h(x) as h(x)→0 = ∞'​, where ∞'​ denotes the complex infinity (which, as its name suggests, doesn't exist on ℝ, the set of real numbers).I'm telling you, the limit doesn't exist. Also fyi, L'hopital's rule doesn't work all the time.
vrmuth,
As described, for your given function, as x approaches 0, makes little sense because the domain cannot include any x value less than 9. You could try some algebraic tricks if you like, but you still have your originally given function. Try using a graphing calculator or a graphing program to display how the function looks, and check what you see "as x approaches 0".
symbolipoint said:
vrmuth,
actually i 've written "does exist " instead of "doesn't exist" ,sorry,thanks for everybody :smile:
Dickfore said:
:biggrin:let's end this thread
can you please show me some example where L'hopital's rule won't work ?
lim x→∞ x/√(x2+1)
This limit actually came up in my electrostatics exam a few days ago.
That's great. It's obviously 1. -_-
I'm just providing an example of l'Hopital's rule failing for the limit.
Harrisonized said:
lim x→∞ x/√(x2+1)
wow! its getting reciprocated each time we apply L'hopital rule , then what's the method to find such limits when l'hopital rule doesn't work ?
Let L \equiv \lim_{x \rightarrow \infty} \frac{x}{ \sqrt{x^2 + 1} }. This is indeterminate form of the type \frac{\infty}{\infty}. Applying the L'Hospital's Rule with:
<br /> f(x) = x \Rightarrow f&#039;(x) = 1<br />
<br /> g(x) = \sqrt{x^2 + 1} \Rightarrow g&#039;(x) = \frac{1}{2} (x^2 + 1)^{-\frac{1}{2}} 2 x = \frac{x}{\sqrt{x^2 + 1}}<br />
Then:
<br /> \frac{f&#039;(x)}{g&#039;(x)} = \frac{\sqrt{x^2 + 1}}{x}<br />
But, notice that this is the reciprocal of the original fraction! So, we have:
<br /> L = \frac{1}{L} \Rightarrow L^2 = 1 \Rightarrow L = \pm 1<br />
The negative limit is impossible since both of the functions are positive. Thus, we are left with L = 1[/jtex].<br /> So, L&#039;Hospital&#039;s Rule does work in this case.
Then:
<br /> <br /> There&#039;s one small error in your work: <b>you assume that the limit does exist</b> to apply L&#039;Hopital&#039;s Rule, while the fact that this limit does exist, or not, is still <i>unknown</i>.<br /> <br /> @vrmuth:<br /> <br /> To solve these types of problem, we often divide both numerator, and denominator by <i>x</i> to the greatest power (in this problem is <i>x</i>).<br /> <br /> \lim_{x \rightarrow +\infty} \frac{x}{\sqrt{x^2 + 1}}<br /> =\lim_{x \rightarrow +\infty} \frac{\frac{x}{x}}{\frac{\sqrt{x^2 + 1}}{x}}<br /> =\lim_{x \rightarrow +\infty} \frac{1}{\sqrt{\frac{x^2 + 1}{x^2}}} = ...<br /> <br /> It should be easy to go from here. Let&#039;s see if you can get 1 as the answer. :)<br /> <br /> Regards,
VietDao29 said:
There's one small error in your work: you assume that the limit does exist to apply L'Hopital's Rule, while the fact that this limit does exist, or not, is still unknown.
Well, you can look at the use of l'Hospital's Rule as a heuristic guide. It does give a correct solution if we make the assumption that a finite limit exists. For those that require a rigorous proof, one can then go ahead and construct an epsilon-delta proof by using these identities:
<br /> \left\vert \frac{x}{\sqrt{x^2 + 1}} - 1 \right\vert = \left\vert \frac{x - \sqrt{x^2 + 1}}{\sqrt{x^2 + 1}} \right\vert = \left\vert \frac{x - \sqrt{x^2 + 1}}{\sqrt{x^2 + 1}} \cdot \frac{x + \sqrt{x^2 + 1}}{x + \sqrt{x^2 + 1}} \right\vert = \left\vert \frac{x^2 - x^2 - 1}{\sqrt{x^2 + 1} \left( x + \sqrt{x^2 + 1} \right)} \right\vert<br />
<br /> \frac{1}{\sqrt{x^2 + 1} \left \vert x + \sqrt{x^2 + 1} \right \vert} = \frac{1}{\sqrt{x^2 + 1} \left( x + \sqrt{x^2 + 1} \right)}<br />
Next, we notice that \sqrt{x^2 + 1} and x + \sqrt{x^2 + 1} are both monotonically increasing, and the following inequality:
<br /> \sqrt{x^2 + 1} &gt; |x|, \forall x<br />
holds (the graph of the hyperbola lies above its asymptotes). For x &gt; M &gt; 0, we have the following series of inequalities:
<br /> \sqrt{x^2 + 1} \left( x + \sqrt{x^2 + 1} \right) &gt; \sqrt{M^2 + 1} \left( M + \sqrt{M^2 + 1} \right) &gt; M (M + M) &gt; 2 M^2<br />
For any given \epsilon &gt; 0, we can find such an M &gt; M_{0} &gt; 0, so that:
<br /> 2 M^2_0 = \frac{1}{\epsilon}<br />
<br /> M_0 = \frac{1}{\sqrt{2 \epsilon}}<br />
<br /> \left( \forall \epsilon &gt; 0 \right) \left(\exists M_0(\epsilon) &gt; 0 \right) \left( \forall x &gt; M &gt; M_{0} \right) \left\vert \frac{x}{\sqrt{x^2 + 1}} - 1 \right \vert \equiv \frac{1}{\sqrt{x^2 + 1} \left( x + \sqrt{x^2 + 1} \right) } &lt; \epsilon<br />
Thus, we had constructed a proof that:
<br /> \lim_{x \rightarrow \infty}{\frac{x}{\sqrt{x^2 + 1}}} = 1<br />
VietDao29 said:
It should be easy to go from here. Let's see if you can get 1 as the answer. :)
Regards,
yes, i can get , thanks :)
  • · Replies 105 ·
