Is a Wave in Quantum Mechanics Ever in Freefall?
  • Thread starter Thread starter ranyart
    Freefall Wave
ranyart
In QM, particles are treated as either waves or particles, a duality exists. A test particle in freefall is used in all manner of ways to explain certain phenonema.
Can the same experiments be equivilent to waves?..can a wave be explained in any way as in 'freefall'?
I'd have to say no.
A particle by its very nature can be described by a position in space. In other words you can tell me where it is, but a wave is streched out over a long(at least longer that point particle) section of space. It makes no sense to speak of a wave as having a "position" so it cannot make sense for you to speak of it free falling.
No you can't. You would have to look at it in a different way. You normally solve the Schrodinger equation to find the wavefunction. In a system with gravity you add the gravitational potential to the Schrodinger equation and then solve it. This is of course not relativistically invariant. But what you find is more or less the same as a particle in a potential well, with bound and free states. I read a Nature article on this once. Perhaps you can find something on it there.
I think you can, but as heumpje says, it will not be relativisticaly invariant. Actually, you do the same thing when solving one electron problems with the Schrödinger equation. In principle, the problem is already solved, you only have to change a few constants in the solution for the hydrogen problem, but it would be of litle interest because there is no situation in nature where a non relativistic aproximation of gravitation interaction at the quantum level is valid. For example, we wouldn't be able to use that solution on the surface of a black hole where gravity is so intense and thus has to be treated relativisticaly.
wouldn't a wave be described by a field?
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
