I Expanding math space implies expanding space?
  • I
  • Thread starter Thread starter negativzero
    Expanding Space
The discussion centers on the relationship between the mathematical description of an electron's potential path and the concept of physical space expansion. It suggests that as the mathematical space required to describe an electron's position increases over time, this could imply a shift from General Relativity's initial conditions to a quantum explanation of space expansion. However, some participants argue that this view may not hold true for electrons in energy eigenstates, as the expansion of potential does not equate to physical space expansion. The conversation also touches on the complexities of quantum mechanics, including the path integral approach and the nature of wave-packet spreading. Overall, the thread emphasizes the need for a deeper understanding of both quantum mechanics and general relativity to clarify these concepts.
negativzero
The minimal necessary math to describe the potential path of an electron expands over time. Second by second, the space necessary to describe the possible positions of the electron expands.
Does that imply expansion of physical space? And does that shift the explanation of the expansion of space from the General Relativists assumption of "initial conditions" to a quantum explanation.
Please. I'm only lawyer with a smattering of math courses. Have mercy GR guys. For once. Just have mercy on me this time.
Astronomy news on Phys.org
Help! Why doesn't potential equal expansion?
I don’t think this is true, at least not for an electron in an energy eigenstate. That is the reason that energy eigenstates are probably the most commonly discussed states.
Likes bhobba
I'm sincerely curious why the thought of needing mercy crossed your mind.
That's all you need. Simply read the following in the sequence posted and much will be clear, and you can do a post to clarify any further queries:
https://www.amazon.com/dp/0465075681/?tag=pfamazon01-20
https://www.amazon.com/dp/B06XC7F6QG/?tag=pfamazon01-20
https://www.amazon.com/dp/0241293324/?tag=pfamazon01-20
To answer your query you are possibly thinking of Feynman's path integral approach. Its just a pictorial way of looking at what's called the path integral - which isn't really an integral in the usual sense - but that is just by the by for now - I can explain it exactly once you have read the above. Whats going on when not observed QM is silent about - there is no 'expansion' - going on - except regarding the spreading of wave-packets - but since what a state is, is hotly contested in various interpretations, that's not the best way of looking at that either - best to just spend a bit of time understanding the formalism. You are a Lawyer - you are a smart dude - you can do it. It will just take a bit pf time.
When you have finished the field theory book I can explain GR, and expansion, very easily using something called Lovelock's Theorem - but not now - you need a bit of background first
Thanks
Bill
Likes JMz
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
