Is the Universe Expanding Slower Now Than in the Past?
The discussion centers on whether the universe is currently expanding slower than in the past, based on the observation that more distant galaxies recede faster. It highlights that not all galaxies are moving away from the Milky Way, with Andromeda set to collide with it. The conversation also touches on how redshift and distance measurements are used to infer the universe's expansion rate, emphasizing that the relationship between speed and distance must be carefully analyzed over time. Additionally, it is noted that observations from different galaxies should yield similar results due to the universe's homogeneity and isotropy. Understanding the evidence for an expanding universe requires careful examination of these relationships.
discord73
if the farther a galaxy is from us the faster it is receding from us, and the closer a galaxy is to us the slower it is receding from us, and since the farther a galaxy is from us the further back in time we are seeing it, does that mean the universe is expanding slower now in the present and was expanding faster in the past?
Also is there a way of observing 2 other galaxies and being able to know or infer the rate at which the universe is expanding in relation to those two galaxies instead of just the rate at which the universe is expanding in relation to our galaxy and other galaxies?
Space news on Phys.org
Hi there,
Fact is that we do not live in a complete linear Universe. There are some galaxies close to the Milky Way, that do not move away from us. Just take our sister galaxy for example. Adnromeda will collide with the Milky Way in a little while. Therefore, it must be getting closer to us.
Cheers
fatra2 said:
Hi there,
Cheers
Yea, that's how galaxies collied, and how we have the local group and all that good stuff. I didn't think I implied in my post that we live in a linear universe
I think you plot redshift (a measure of expansion between emission and observation) compared to distance (note: over cosmological distances, not just the local group), and find that, for example, a signal emitted 1bn years ago has more than half the redshift than a signal emitted exactly 2bn years ago, implying that the known amount of expansion occurs disproportionately in recent times.
Redshift is easy to find from standard candles and using luminosity distances, but I'm not sure how the distance itself is found (there are 4 parameters, redshift, distance, luminosity and observed intensity, and I can only see how 2 are observed)
Distance is determined by finding a standard candle, such as a super nova, in another galaxy then compareing it's known luminosity to it's apparent luminosity since light behaves by the inverse square law I believe, an object twice as far from us will appear 4 times fainter.
That would be ok, but for the 1a supernovas which were used as evidence for accelerated expansion, the formula is modified to include the redshift for distances over which cosmic expansion is no longer negligible (eg. the light will be redshifted gravitationally, and as the universe expands, the density of photons falls, giving you a superficially low intensity).
The distance is (1+z) times closer than you would think in a universe that has expanded by redshift z between observation and emission.
you can't infer that from your statement.
There is nothing special about our Earth frame fo referenece...we are just another speck in the universe. It's believed the universe is homogeneous and isotropic so whether you make measurements and observations here or from a galaxy a billion light years away it is expected results will be the same.
Well, no what you've described is just simple expansion. To have an idea of how that expansion has changed over time, you have to look very carefully at how the relationship between speed and distance changes as you look further back into the past.
Yes. It's just a simple coordinate transformation.
Can someone explain in clear terms what the evidence is for an expanding universe? I think I may be close in my above post but don't think I understand where all the evidence comes from. I've tried reading the 1998 paper but it's more experimental than theoretical
This essay may help:
http://www.talkorigins.org/faqs/astronomy/bigbang.html
