Explaination of voltage drop across resistors
The discussion revolves around the concept of voltage drop across resistors, particularly in the context of Ohm's law. Participants explore the relationship between voltage, resistance, and current in electrical circuits, addressing both theoretical and practical implications.
  • Some participants inquire about the relationship between voltage and resistance, specifically why voltage increases with resistance according to Ohm's law.
  • One participant explains that in a series circuit with two resistors, increasing the resistance of one resistor leads to an increase in the voltage across that resistor, referencing a specific formula.
  • Another participant expresses confusion about how an increase in voltage could lead to an increase in resistance, clarifying that resistance does not increase with voltage.
  • A participant discusses the work done to push current through a resistor, suggesting that larger resistance requires more work, resulting in a larger voltage drop.
  • Questions arise regarding the implications of having zero resistance in a circuit, with discussions on the undefined nature of current in such cases.
  • Some participants mention that Ohm's law does not provide information when resistance is zero, noting that voltage must also be zero in that scenario.
  • There is a mention of real-world scenarios where resistance is never truly zero, except in superconductors.
  • One participant draws an analogy between voltage and current with kinetic and potential energy, suggesting a conservation of energy perspective.
  • A question is posed about why all voltage from a battery would drop across a resistor, regardless of its resistance value, leading to a discussion on voltage division and practical considerations in real-life circuits.
  • Another participant notes that in practical applications, such as in mines, the resistance of wires can significantly affect voltage drop, complicating the ideal assumptions.
Participants express varying levels of understanding regarding the relationship between voltage, resistance, and current. While some explanations are provided, there is no consensus on the fundamental questions raised, and multiple perspectives on the implications of zero resistance and voltage drop remain unresolved.
Limitations include assumptions about ideal conditions versus real-world applications, as well as the complexities introduced by factors like wire resistance and the behavior of superconductors.
SyNtHeSiS
I want to know that if there is a voltage drop across a resistor, why is it that voltage increases as resistance increases (Ohm's law)?
None.
N/A
What do you mean by saying
can you explain.
In Ohm's law, resistance is directly proportional to voltage, but I want to actually know why voltage increases, as resistance increases.
ohh are you asking similar to this :
In a circuit with two resistors R1 and R2 connected in series to a voltage source V, if R2 increases why voltage across R2 increases?
Well, the formula for voltage across R2 (say v2) is
[tex]V_2=\frac{R_2}{R_1+R_2} \times V[/tex]
From this relation, you can deduce that if R2 is increased, V2 is definitely going to increase.
BTW Ohm's law says that (at constant temperature) current flowing in a conductor is proportional to voltage applied across it and the proportionality constant is 1/Resistance.
No I ment like I understand why current increases, as voltage increases (cause you supplying more energy in a way which makes a stronger current). But I don't see how an increase in voltage leads to an increase in resistance.
You don't get and increase in resistance by increasing voltage.
Larger resistors have larger voltage drops. Why? Before we can answer that we must better understand what exactly a resistor does.
A resistor resists the flow of current. This resistance means that some work must be done to "push" current through the resistor. Whenever work is done on charge, we have voltage. Thus, when current flows through a resistor, there is some voltage across the resistor.
The larger the resistance, the more work required to "push" the current through the resistor, the more work done the larger the voltage drop across said resistor.
Thanks for the explanation. And something which has been bugging me is say you had a circuit with no resistance and you wanted to calculate the current, how would this be possible since: I = V / 0 would be undefined?
The only hope to obtain a finite answer for the current would be if V=0. That's why in an ideal conductor, the voltage difference between any two points is zero.
There are also effects like inductance and capacitance, which will keep the current from diverging due to a change in potential.
How would this be possible since if V=0 then I = 0/0 would still be undefined?
Better to say indeterminate than undefined. You can avoid the division by zero if you write Ohm's law in its traditional form, V=IR. If R=0, the voltage has to be 0, but the current could be any value.
You wouldn't be able to determine I using Ohm's Law right? Since a circuit must contain a resistor to obey Ohm's Law?
Right. Ohm's law doesn't tell you anything when the resistance is zero other than the voltage has to be zero as well.
Realistically you would never have a case where the resistance is totally 0 would you? I mean, there would always be some infinitesimal amount of resistance, no?
For your normal, everyday conductors, like copper wire, yes, there is always some resistance. Superconductors, however, do have 0 resistance.
Voltage and current are like kinetic and potential energy, there must be conservation of energy. Therefore, as voltage increases current decreases and vice versa.
Oh ok also say you had a circuit with only a +20V battery and one resistor connected in series with it to earth. Why is it that all 20V would be dropped across the resistor, even if R = 10 ohms or if R = 1k ohm?
We could analyse how the Voltage is slowly reduced over very small increments of wire resistance as if we are doing a voltage divider, but relatively, the resistance of wire is most likely negligable compared to the resistance of the resistor.
For ease of calculations we assume the resistance of the wire to be zero.
In real life this is not how it always works, for example in mines where machines operate underground on 415V sources, a lot of the time generators produce ~433V because the length & resistance of the cables used drops a significant amount of voltage.
  • · Replies 18 ·
  • · Replies 17 ·
13K
