Explaining Hydrogen-Like Ions and Quantum Numbers for Li2+
  • Thread starter Thread starter 8614smith
    Hydrogen Ion
8614smith
(a) Explain the term Hydrogen like ion and determine the quantum numbers l,m for the Li2+ ion in the states for which n=1 and n=2.
(b) Explain why for a hydrogen-like ion it is reasonable to use the relations,
\mu\approx{m_e}, {E_n}=-13.6\left(\frac{Z^2}{n^2}\right)
(c) What are the energies of the n=1 and n=2 states in Li2+ ?
reduced mass
(a) A hydrogen like ion is an atom with only 1 electron
(b)\frac{{M_N}{M_e}}{{M_N}+{M_e}} I've then said that the M_e term on the denominator is negligible and the M_N terms will cancel.
This are from my notes but reading over them i don't understand it.
(c)I don't know how to do this, when i put n=1 and n=2 into the equation, using Z=1, i don't get the right answer. The correct answers are -122.4eV for n=1 and -30.6eV for n=2.
any hints??
b) You have the answer already. The mass of the electron is so small compared to the mass of the nucleus that effectively you just have a particle orbiting an "infinite" mass (i.e. the nucleus won't be affected by the electron much).
c) Z=1 is for Hydrogen, not Li2+. Do you know what the Z stands for in that equation?
Ah yes stupid mistake, (c) is fine then, but (b) i still don't get, what does the reduced mass actually represent?
When you work with a reduced mass, you effectively reduce a system from 2 particles orbiting the center of mass to a system of 1 particle with the reduced mass orbiting the center of mass. This makes many calculations easier, since you don't have to deal with 2 particles all the time. For the system with one mass significantly more massive than the other mass, the center of mass is very close to the center of the massive object. So, in effect your system is already reduced to 1 particle with the "reduced mass=actual mass of the orbiting particle" orbiting around the center of mass.
Ok thanks, that's cleared it up for me!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
