Explaining the Frequency of Oscillation of a Mass Attached to a Spring
The discussion revolves around the frequency of oscillation of a mass attached to a spring, specifically addressing the effects of the spring's mass on the oscillation frequency. Participants explore both energy conservation and force approaches to derive the frequency, questioning the validity of assumptions made in the derivations.
  • Some participants assert that the potential energy formula U = 1/2 k x^2 remains valid even when considering the mass of the spring, as long as M << m is assumed.
  • Others argue that the inertia of the spring affects the displacement along its length, complicating the derivation of the frequency using forces.
  • A participant attempts to derive the frequency using forces, leading to a different expression for ω², which raises questions about the assumptions made regarding the forces acting on the spring.
  • There is a discussion about the kinetic energy of the spring, with some participants noting that the kinetic energy should be integrated over the length of the spring rather than assuming it is 1/2 Mv².
  • One participant expresses confusion about why the force approach yields incorrect results, suggesting that the internal forces in the spring may not cancel as expected.
  • Another participant introduces a more complex expression for ω that includes higher-order terms, indicating a potential for more nuanced models of the system.
Participants do not reach a consensus on the validity of the force approach versus the energy approach. Multiple competing views remain regarding the impact of the spring's mass on the oscillation frequency and the application of Hooke's Law in this context.
Limitations include unresolved mathematical steps in the derivations, particularly regarding the integration of kinetic energy over the length of the spring and the assumptions about the uniformity of forces within the spring.
dEdt
My textbook derived an expression for the frequency of oscillation of a mass m attached horizontally to a spring with mass M and constant k. Assuming that M<<m, it got that
\omega^2 = \frac{k}{m + M/3}.
The author used the conservation of energy to get this expression, but he assumed that the total potential energy still still satisfies U = \frac{1}{2} k x^2, where x is the extension of the spring. Why is this formula still correct?
Also, I wanted to derive the same result using forces, but I'm having some trouble. How would I go about this? Thanks a lot!
Because M << m, you can assume the inertia forces on the spring's own mass M do not affect the deformation in the spring. In other words, if you measure from the fixed end, the spring is length L, and the motion of the large mass m is A sin w t, then the motion of any point the length of the spring is
u(x,t) = A (x/L) sin wt
This is the same as for a massless spring, so the potential energy is the same.
The M/3 term comes from the extra kinetic energy of the mass M. You can find that by integrating along the length of the spring.
This is only an approximate solution, because the inertia of the spring does affect the displacments along its length, and the equation for u(x,t) given above ignores that fact.
hi dEdt! :smile:
(have an omega: ω :wink:)
dEdt said:
… he assumed that the total potential energy still still satisfies U = \frac{1}{2} k x^2, where x is the extension of the spring. Why is this formula still correct?
it's always correct (for the PE)
the only relevance of M << m is that he's ingoring the KE of the spring :wink:
you should get the integral of the energy equation :confused:
show us what you did get :smile:
Here's what I (tried) to do with the force approach:
The external force on the spring-mass system is the force from the wall on the spring F_w it is attached to. So F_w = (M + m) \frac{d^2}{dt^2}x_{cm}, where x_cm is the position of the center of mass. Subbing in x_{cm} = \frac{mx + Mx/2}{m+M} (x is now measured from wall) and F_w = k \Delta x gives that
\omega^2 = \frac{k}{m+M/2}. :S
hi dEdt! :smile:
dEdt said:
… I wanted to derive the same result using forces …
the trouble with using forces is that the two forces at opposite ends of the spring are not the same …
you're used to the tension or compression in a rod (or a spring) being the same at both ends, but that's only if the centre of mass isn't moving :wink:
in this case, you cannot say Fw = k∆x, you'd have to find equations for Fw and Fm, use Fw - Fm = Mx''/2, and eliminate the Fs :redface:
now do you see why it's so much easier to use energy? :biggrin:
Well, I thought that because the mass of the spring was small, I could approximate that the forces on the two ends of the spring were the same.
At any rate, if I go about it your way, I still get the wrong answer! I get that \omega^2 = \frac{k}{m+M}.
The only possible resolution to this contradiction would be that the force of the spring on the mass is not -k\Delta x. This would make sense, because if not, the period of the mass shouldn't be different than when it's massless because the force doesn't change. But then what's Hooke's Law for a massive spring?
hi dEdt! :smile:
hmm … you've obviously used 1/2 mv2 + 1/2 Mv2 + 1/2 kx2 = constant
that's wrong because the kinetic energy of the spring is not 1/2 Mv2
that would be correct only if the whole spring had velocity v …
you'll have to integrate (over the length of the spring) to find what the correct KE is :wink:
Sorry Tiny-tim, I botched my last post.
What I meant to say when I said that I would try your way was that I would use Fw - Fm = Mx''/2, which gives me the omega I wrote before. Sorry for the confusion (with energy, I did, following my textbook, use 1/6Mv2).
So, does Hooke's Law change with a massive spring?
no, Hooke's Law is still the same …
it only concerns the force, and has nothing to do with the mass or inertia :smile:
(and for example the spring energy is totally separate from the kinetic energy, and indeed from gravitational potential energy)
Alright, by why doesn't the force approach work then? We have
F_m - F_w = \frac{Mx&#039;&#039;}{2}, -F_w = (m+M)(x_{CM})&#039;&#039;, and F_m = kx.
Combining these together, and using that x_{CM}&#039;&#039; = (mx +Mx/2)/(m+M), I get a wrong expression for the angular frequency. I'm confused, help! :(
hmm … i think the problem is that tension in a massive spring varies along its length (quadratically, i believe) …
but i don't know the formula for it …
perhaps you can work it out? :wink:
Should that matter? wouldn't the internal forces just cancel?
I think the problem is with Hooke's Law, personally
Spring usually use to absorb the energy.Where it is needed to absorb huge amount of energy there usually use massive spring.Their absorbing power is outstanding.energy absorb equation can be written as-
ω = [k/(M + m/3 + o(m2/M) )]1/2.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 27 ·
