Are Mercury-Vapor Lights Considered Incandescent Lights?
  • Thread starter Thread starter stickythighs
    Lights
Mercury-vapor lights are not classified as incandescent lights because they do not emit light through the heating of a filament, which is the defining characteristic of incandescent lighting. Instead, mercury-vapor lamps produce light through electron transitions in gas, resulting in a broader spectrum of light compared to the single-color emission of low-pressure sodium lamps. In the United States, most street lights are typically mercury-vapor or sodium-vapor lights, rather than incandescent lights. While LEDs are emerging as a potential option for street lighting, they are not yet widely used in this context. Therefore, by definition, mercury-vapor lights are distinct from incandescent lights.
stickythighs
By definition, are all mercury-vapor lights NOT incandescent lights?
In practice, are mercury vapor lights ever incandescent lights?
Are most street lights in the United States incandescent lights or mercury-vapor lights or sodium vapor lights or some other type of lights?
Computer science news on Phys.org
Incandescent lights are ussually defined as those that glow because of the blackbody emission from a hot filament (incandescent=heat).
Fluorescent lamps (including Hg and Na) emit light in discrete lines from electron transitions. Low pressure sodium uses only a single line (actually a close together pair) so you get only a single colour (orange) but it is efficent since almost all of the energy goes into this line. Mercury gives a much whiter ligth because it has so many lines and the pressure of the vapor broadens them so they almost overlap - giving a nearly continuous spectra.
The other class of lights would be LEDs but they aren't used in street lighting - yet.
So by definition Mercury-vapor lights are not incandescent lights?
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
