How Does Light Reflect on Paper with Dual LED Angles?
Light reflects off paper in two primary ways: specular reflection, where the angle of incidence equals the angle of reflection, and diffuse reflection, where light scatters in all directions. When using two LEDs at equal angles to illuminate a single point on paper, the contributions of each LED can be analyzed separately due to the lack of interference effects. Although the LEDs emit light in the same wavelength range, they are not coherent, meaning they do not produce phase-dependent effects like interference. A detector can be placed between the LEDs to capture reflected light, but the amount detected will vary based on the LEDs' output, environmental noise, and the paper's scattering properties. Understanding these principles is crucial for applications involving light reflection on surfaces.
kdkdkd
imagine that i have a pair of LEDs throwing light on the same point on a piece of paper. This is possible if the LEDs are inclined equally at an angle to the normal coming out of paper, right?
now if i consider two rays hitting the paper at the same point, then where can i explain the presence of the reflected ray as, is it:
1) along the normal coming out of the paper
2) partly along this normal and partly through one of the paths of incidence(since angle of incidence = angle of reflection).
3) scattered everywhere.
or is it any other answer.
help is appreciated. :confused:
Science news on Phys.org
You can start off by dividing the problem into two sections - first you figure out the contribution of one LED to what you see, then you figure out the contribution of the other LED, then you add them together. This is possible because the two LED's won't produce any interference effects, they are not coherent.
Now, when light hits a paper, some of it will reflect like a mirror, where the angle of incidence is equal to the angle of reflection. This is called specular reflection.
Other light will scatter in all directions - this is called diffuse relflection.
You'll usually see a more mathematical treatment of these sorts of problems in "ray tracing" for generation of computer images.
With flat objects, specular reflection just means glare when the object is tilted correctly, with round or curved objects (like an apple), specular reflection will create "highlights"
I didn't find anything helpful for "typical" values for specular vs diffuse reflection coefficients for paper in a quick google.
thanks a lot for your reply. it was heartening to note that there are no interference effects... though I am not entirely convinced about this. if the LEDs are of the same make, let out light in the same wavelength range, isn't the spectral equation governed by:
reflected ray property = integral ( spectral property of incident * spectral property of surface of incidence)
since both LEDs strike the same surface, the incidence surface property is also constant. so aren't they coherent??
could you enlighten me about the prominence of one particular kind of reflection over the other. If specular reflection were prominent enough, then could i successfully place a light detector between the LEDs, i.e along the normal?
thanks again.
Coherence relates to the phase of the emitted light. Photons emitted by an LED are not in phase, thus any phase dependant effects (such as interference fringes) will be washed out. Laser Diodes by contrast emit photons that are in phase, and thus will exhibit interference effects.
Claude.
thanks claude, i guess pervect was also trying to convey your idea.
my actual doubt still remains...
is it possible to place a detector between the two inclined LEDs (remember the LEDs direct light to a single point on paper) and detect the reflected light to a large extent?
good day.
Yes, if you place a detector there you will certainly detect something, how much depends on the output of the LED's, the optical noise coming from the surrounding environment, and how much the paper scatters the light.
Claude.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
