MHB Solving Exponents: Simplifying Radical Expressions
  • Thread starter Thread starter CSmith1
    Exponent
The discussion focuses on simplifying radical expressions and understanding when to use square root form versus powers. The example of 8 raised to the power of 3/2 is worked through, ultimately leading to the answer of 16 square root 2. Participants clarify that answers should be simplified to their most basic form, with square roots retained when necessary. It is noted that in practical applications, such as engineering, decimal approximations may be preferred over exact forms. The conversation emphasizes the importance of clarity and simplification in mathematical expressions.
CSmith1
=(81/2)3
=(2 squareroot 8)2
(2 square root 2x2x2)3
=(2 square root )3
=2 square root x 2 square root x 2 square root=8 (2 square root)
=16 square root 2
Mathematics news on Phys.org
CSmith said:
1.) 8 3/2
=(81/2)3
=(2 squareroot 8)2
=(2 square root )3
=16 square root 2
It's a little hard to follow your work but the final answer is correct! (Clapping)
Thanks!:) I am trying...
how do i know when the answer should be in square root form like 16 square root 2 or when it is suppose to be in powers like my answer for 32 2/5 when the answer was 2^2.
The final answer to that problem is 4. There's no reason to write it as 2^2.
With square roots, you simplify as much as you can until you are left with a prime number, so you must keep the square root sign or use a decimal approximation, which is not preferred. If you have something like [math]\sqrt{20}[/math] then you can simplify it but there will be a square root in the final answer.
True so far as it goes. An engineering professor is not necessarily going to want a highly complicated but exact answer when an easy-to-understand decimal approximation helps the bridge get built more easily.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
