Exponential functions word problem
The function T=190(1/2)^(1/10t) is used to determine how long milk remains fresh at a given temperature, specifically 22 degrees Celsius. To solve for t in the exponent without using logarithms, one approach is to equate the temperature value to the function and explore powers of 1/2. The discussion highlights the difficulty of dividing 22 by 190 and suggests trying various values or using a graphing calculator for a quicker solution. Clarification is sought regarding the correct interpretation of the exponent, emphasizing the importance of accurately inputting exponents in calculations. The conversation ultimately revolves around finding practical methods to solve the exponential equation without logarithmic functions.
Coco12
The function T=190(1/2)^1/10t can be used to determine the length of time t, in hrs that milk will remain fresh. T is the storage temp. In Celsius
How long will milk remain fresh at 22 degrees Celsius
Bases have to be same then exponents will equal one another
In this equation , we need to solve for the t in the exponent. I thought you has to divide 22 (T) by 190 and tried to make it so that the base is the same as (1/2) but the number when you divide 22 by 190 is a very long decimal and I don't know how to do that. So far we have not done Logs yet in class so how can I solve that without using logs?
"Bases have to be same then exponents will equal one another"
It's unclear what this statement means, and I don't think it will help solve the problem.
Don't you understand how logarithms work? Try taking the logarithm of both sides of the Temperature equation.
Remember that e^(ln x) = x
Surely you are not going to let a number, even a very long one, scare you? The fact that you have not done logarithms is more important. 22/190= 0.115789, approximately, and if I don't want to (or can't) use logarithms then I had better think in terms of powers of 1/2. I know that (1/2)^3= 1/8= 0.125 and (1/2)^4= 1/16= 0.0625 so the nearest I can do is that 1/(10t) is about 3.
yes, without using logarithms, the simplest method is probably the tried-and-tested, backup-option of just trying a few values, and choosing the one that fits the equation the closest.
Ok thank you , could I also use a graphing calculator?
Is the exponent (1/10)t or 1/(10t) ? Also you can press the little X2 button to do exponents properly.
@Coco12: yeah, that should work. when it draws the graph of the function, it will essentially do the same thing you are (i.e. choose a bunch of values and calculate what the function evaluates to). except it will generally be faster than a person. be careful to avoid t=0
To get to that extended menu, click Go Advanced. The X2 let's you enter exponents so they appear in a nice format.
  • · Replies 17 ·
