Can the General Solution for this Exponential Equation be Found?
In summary, the conversation discusses different methods for solving the equation \frac{d^2f\left(x\right)}{dx^2}= A\exp\left(f\left(x\right)/B\right), which comes from plasma equilibrium. The methods involve making substitutions and using integrals to find the general solution, which can be expressed as f = -2B\ Ln\left(ch\left(\sqrt{\frac{A}{2B}}x\right)\right) or f = C_1 + C_2\tanh^{-1}\left(\sqrt{\frac{A}{2B}}x\right), depending on the values of A and B. However, there is no simple exact solution for this
Heimdall
42
Hello,
I'm trying to solve this equation :
[tex]\frac{d^2f\left(x\right)}{dx^2}= A\exp\left(f\left(x\right)/B\right)[/tex]
(which comes from plasma equilibrium)
I can't find out what's the general solution... is there a method to solve with this kind of second member
Well, you can make some headway as follows:
[tex]\frac{d^{2}f}{dx^{2}}f'(x)=Ae^{\frac{f}{B}}f'(x)\to\frac{1}{2}((f'(x))^{2}-(f'(x_{0}))^{2})=BA(e^{\frac{f(x)}{B}}-e^{\frac{f(x_{0})}{B}[/tex]
Whereby it follows that:
[tex]f'(x)^{2}=Ce^{\frac{f}{B}}+K[/tex]
where C=2AB, and K depends on the values of the function and its derivative at [itex]x_{0}[/tex]
There is no particular reason why this should have a simple exact solution.
lets say that [tex]f\left(x_0=0\right)=f'\left(0\right)=0[/tex]
so that we have :
[tex]f'^2 = 2BA\left(\exp\left(f/B\right)-1\right)[/tex]
or [tex]f'^2 = 4AB\exp\left(f/2B\right)sinsh\left(f/2B\right)[/tex]
I know there's a trick somewhere because the solution should be something like
[tex]log\left(cosh\left(\right)\right)[/tex]
Okay, let's see:
Let:
[tex]u^{2}=e^{\frac{f}{B}}\to{2u}\frac{du}{dx}=u\frac{f'}{B}\to{2Bdu}=f'dx[/tex]
This substitution seems very promising..
We get:
[tex]\frac{f'}{\sqrt{2AB}\sqrt{e^{\frac{f}{B}}-1}}=\pm{1}[/tex]
which leads to:
[tex]\sqrt{\frac{2B}{A}}\int\frac{du}{\sqrt{u^{2}-1}}=\pm{x}+C[/tex]
We set u=Cosh(v), yielding:
[tex]\sqrt{\frac{2B}{A}}sgn(Sinh(v))v=\pm{x}+C[/tex]
essentially yielding the result for f you mentioned; just get the signs right.
Hum,
[tex]2u\frac{du}{dx} = \frac{f'}{B}e^{f/B} = \frac{f'}{B}u^2[/tex]
which means that
[tex]2B\frac{du}{u} = f'dx[/tex]
now the integral is :
[tex]\int\frac{2Bdu}{u\sqrt{u^2-1}}[/tex]
and with your u = ch(v) you get
[tex]\int \frac{dv}{ch\left(v\right)}[/tex]
Okay, made a mistake there.
I've looked on the web and
[tex]\int \frac{dv}{ch\left(v\right)} = gd\left(v\right)[/tex]
where gd(v) is the Gudermannian function :
[tex]gd\left(v\right) = 2\arctan\left(th\left(\frac{v}{2}\right)\right)[/tex]which doesn't look nice if you come back to f
I haven't seen it the first time but you can't even do this if x=0 (because f(0)=0)
That need not be destructive, since f' is zero also.
You have an improper integral.
Heimdall said:
Hum,
which means that
So, then we continue!
We set y=tanh(v/2)[tex]\frac{dy}{dv}=\frac{1}{2}\frac{1}{Cosh^{2}(\frac{v}{2})}=\frac{1}{2}(1-y^{2})\to{dv}=\frac{2dy}{1-y^{2}}[/tex]
Thereby, we get:
[tex]\int\frac{1*dv}{Cosh(v)}=\int\frac{Cosh^{2}(\frac{v}{2})-Sinh^{2}(\frac{v}{2})}{Cosh^{2}(\frac{v}{2})+Sinh^{2}(\frac{v}{2})}dv=\int\frac{1-y^{2}}{1+y^{2}}\frac{2dy}{1-y^{2}}=\int\frac{2dy}{1+y^{2}}=2arctan(y)+C[/tex]
And we are essentially done. :smile:
I didn't see this post. Sorry about that.
Hi :)
In the mean time I got another solution :
[tex]I = \int\frac{f'dx}{\sqrt{1-\exp{\left(f/B\right)}}}[/tex]
let [tex]u^2 = 1-\exp{\left(f/B\right)}[/tex]
so we have :
[tex]-2Budu\frac{1}{1-u^2} = f'dx[/tex]
and we get :
[tex]I = -2B\int \frac{du}{1-u^2} = -2Bargth\left(u\right)[/tex]
[tex]I = -2Bargth\left(\sqrt{1-\exp{\left(f/K\right)}}\right) = -\sqrt{2AB}x[/tex]
[tex]\sqrt{1-\exp{\left(f/B\right)}} = th\left(\sqrt{\frac{A}{2B}x}\right)[/tex]
[tex]f = -2B\ Ln\left(ch\left(\sqrt{\frac{A}{2B}}x\right)\right)[/tex] :)
Note that in this case, you have 1-exp beneath the square root sign; not exp-1.
That will naturally yield a totally different solution, valid whenever AB<0, K>0.
1. What is an exponential second member?
An exponential second member is a term in an exponential equation that is raised to a power. It is typically represented by the letter "b" and determines the rate at which the exponential function increases or decreases.
2. How is an exponential second member different from the first member?
The first member in an exponential equation is the base, which is typically represented by the letter "a". It does not change and remains constant throughout the equation, while the second member, or "b", determines the rate of change.
3. What is the significance of the value of the exponential second member?
The value of the exponential second member determines the steepness of the exponential curve. A larger value will result in a steeper curve, while a smaller value will result in a flatter curve.
4. How do you solve for the exponential second member?
To solve for the exponential second member, you need to have two sets of data points from the exponential function. You can then use the formula b = (y2/y1)^(1/x2-x1) where b is the second member, y1 and y2 are the y-values, and x1 and x2 are the corresponding x-values.
5. What are some real-life applications of exponential second members?
Exponential second members are commonly used in finance, economics, and science to model exponential growth or decay. They can also be used in population growth, compound interest, and radioactive decay calculations.
  • Differential Equations
