I How do I evaluate the Taylor series for ##Si(x)## around a given value?
The discussion revolves around evaluating the Taylor series for the sine integral function, Si(x), particularly in the context of approximating sin(A*B) using the expression involving Si(B^2) and Si(A^2). Participants explore whether to expand Si(x) around A^2 or B^2 and the implications of using this approximation when A and B are close. There is a consensus that the formula's accuracy diminishes when A and B are large, as the logarithmic term in the denominator can significantly affect the result. The conversation also touches on the general behavior of integrals involving functions and the importance of convergence in power series. Ultimately, the participants express caution about the assumptions underlying the formula's validity, especially for larger values of A and B.
Kumar8434
Hi, I've got this:
$$\sin{(A*B)}\approx \frac{Si(B^2)-Si(A^2)}{2(\ln{B}-ln{A})}$$, whenever the RHS is defined and B is close to A ( I don't know how close).
Here ##Si(x)## is the integral of ##\frac{\sin{x}}{x}##
But, to check it, I need to evaluate the ##Si(x)## function. I'm new with Taylor series, so, how am I supposed to do it? The only confusion is that should I work with the Taylor series of ##Si(x)## around ##x=A^2## or ##x=B^2## to check it? How do I evaluate ##Si(B^2)-Si(A^2)## approximately?
Mathematics news on Phys.org
I think this result is true for any function ##f(x)##. To get the expression for ##f(A*B)##, just replace ##Si(x)## by the integral of ##\frac{f(x)}{x}##.
I think it can be converted into a (maybe) useful result as it would mean:
$$\int_a^b\frac{f(x)}{x}dx\approx f(\sqrt{ab})*\ln{\frac{b}{a}}$$
EDIT: Ok. Now I don't think the above result is true for general functions. It gave a false result for ##f(x)=\ln{x}##.
EDIT2: Sorry, I again checked for ##f(x)=\ln{x}##. I did a mistake last time. It's absolutely true for ##\ln{x}##. I think its true for general functions.
If you know how to expand sin(x) in a Taylor series, you can evaluate Si(x) by dividing each term in the series by x and then integrating term by term. After a quick look, my impression is that your result for sin(A.B) works only if A and B are close and not too large.
Try putting B = A + x or
B = C + y,
A = C - y
and expanding the results.
The general pattern appears to be: Given ## a < m < b## then ##\int_{a}^{b} f(x)g'(x) dx \approx f(m) (g(b) - g(a)) ##. So the question is whether the particular case of ## g'(x) = \frac{1}{x} ## and ##m = \sqrt{ab}## is more useful than other examples of that general pattern.
Try ##\int_1^4 \frac{(x-2)^2}{x} dx ##.
Yeah, it didn't work for ##f(x)=(x-2)^2##. But I'm convinced that ##\sqrt{ab}## is the most useful candidate for ##m## in case of non-polynomial ##f(x)##.
Try ##\int_{\frac{2}{3}}^{\frac{3}{2}} \frac{ (\ln(x))^2}{x} dx ##
Ok, that didn't work either. But I must say now that ##\sqrt{ab}## is the best choice for 'm' in case of elementary functions which are not compositions of two functions. And, please don't give a clever example to make my expression 0.
Ok. I haven't done calculations but now I guess the arithmetic mean might be a better m for any function.
Can you prove it is really the "best" choice?
That question can be turned into a well-defined problem of calculus. For example: Find the value ##m## that minimizes the function ##S(m) = ( \int_a^b \frac{ f(x)} {x} dx - f(m)(\ln(b) - \ln(a)))^2 ## where ##f(x)## is some elementary function of your choice.
B = C + y,
A = C - y
I'm not sure but I believe the actual requirement of the formula is ##logA## should be close to ##logB## instead. Could you check it for ##A=100## and ##B=110## by a computer program. I'd have to evaluate too many terms for that.
Could you check it for A = 100 A 100 and B = 110 B 110 by a computer program. I'd have to evaluate too many terms for that.
There may be ways of calculating the integrals without doing hundreds of terms or using a computer. But let's try a fairly simple sanity check first.
The denominator in the integral will vary between 10,000 and 12,100, roughly a 20% change. Since (1/x) is a smooth function, we can get a reasonable estimate of the integral by holding the denominator constant at its average value of about 11,000. Then all we have to do is integrate sin(x) between x = 12,100 and x =10,000. This integral is the difference in the corresponding cosines, which my calculator tells me is about 1.11. Dividing by 11,000 gives about 1.0x10-4, and dividing that by your denominator equal to 2.ln(1.1) gives about 5.2x10-4.
The left hand side of your equation is sin(11000), which, again according to my calculator, is about -0.96.
I got a similarly unpromising result with B = 2 and A = 1 (it is necessary to integrate the series then), but I'll let you check that for yourself.
I think I made a sign error, meaning the estimate should be -5.2x10-4..
But it seems clear that there is problem with your formula for this range of values. If A and B are of order 100, Si(A2) and Si(B2) must be of order 10-3 or 10-4 unless A and B are so close that the logarithm in the denominator is also very small.
Starting with your values, a shift in A2 or B2 by an amount of order 2π cannot make the absolute value of your formula greater than a few times 10-4 (such a shift could decrease it). But changing A and B by the corresponding amounts in your left-hand side would cause the argument of sin(A.B) to vary by a large fraction of a revolution, meaning that the sine itself could approach ±1.
In other words you could pick values of A and B that were very close to the ones you chose and that would make sin(A.B) = 1; but those values of A and B could not make Si(B2) - Si(A2) any greater than about 10-4.
I already told you that ##logA## and ##logB## should be close, which would make the fractional large even if the numerator is small. Since the graph of logarithm almost becomes parallel to the x axis, so, the formula would work even when A and B differ by large amounts. And, I checked for A=1 and B=2. The value of sin(2) is 0.9 and the formula gave 0.81, which isn't very bad because log2 and log1 differ by 0.69.
And the formula should certainly work if there's no bug in this:
$$\text{Si}\left(x\right)=\text{Si}(a)+\frac{(x-a) \sin (a)}{a}+O\left((x-a)^2\right)$$
Then, composing series
$$\text{Si}\left(B^2\right)=\text{Si}\left(A^2\right)+\frac{2 (B-A) \sin
\left(A^2\right)}{A}+O\left((B-A)^2\right)$$
$$\log(B)=\log (A)+\frac{B-A}{A}+O\left((B-A)^2\right)$$ which make
$$\frac{\text{Si}\left(B^2\right)-\text{Si}\left(A^2\right)}{2 (\log (B)-\log (A))}=\sin \left(A^2\right)+A (B-A) \cos \left(A^2\right)+O\left((B-A)^2\right)$$ while $$\sin(AB)=\sin \left(A^2\right)+A (B-A) \cos \left(A^2\right)+O\left((B-A)^2\right)$$
Si(x)=Si(a)+(x−a)sin(a)a+O((x−a)2)
SixSiaxasinaaOxa2
Let's look at the case where x and a are much greater than unity.
Si(∞) is finite, in fact equal to π/2
So Si(a) = π/2 -∫a( sinx/ x) dx
Integrating by parts twice gives
Si(x) = π/2 + cosx/x]a + ∫acosx / x2 dx
=π/2 - cosa/a + ∫acosx / x2 dx
π/2 - cosa/a - sina / a2 + 2asinx / x3 dx
The remaining integral cannot be numerically greater than 1/a2; so, replacing a by B2 and A2 successively, we get
Si(B2) - Si(A2) ≈ cosA2/A2 - cosB2/B2 + O(1/A4) +O(1/B4)
which is O(1/A2) if A and B are reasonably close.
If A =100 and B/A =1.1, ln(B2/A2)= 0.19, leaving your expression of order 10-3 at best.
I'm not saying your equations are absurd; they do work (surprisingly) well in most of the cases you've examined, but to me it looks as though they're built on some hidden assumptions that may not always be true, and this is a case where those assumptions don't apply. I suspect the problem is to do with the asymptotic behaviour of Si(x), a function that flattens very quickly.
I can't find my earlier calculation and my algebra skills aren't what they were, but I get 0.59 from your formula: Si(4) ≈ 1.767; Si(1) ≈ 0.953; 2ln(2) = 1.386.
One more thought. You certainly can't assume the series is converging after two terms unless (x - a)2 is small--meaning much less than unity. It would be instructive to work out a couple of terms in the expansion and consider how they behave when a, x, and (x - a)2 are all greater than unity.
Oh, I guess I had divided by ln(2) instead of 2ln(2) earlier. I always do elementary mistakes even with a calculator. I think you're right. These equations don't work in most cases.
I make a lot of errors myself these days. To get anywhere is a matter of gathering up time and patience and being prepared to check everything a couple of times.
I would stress, though, that when you develop a power series you should investigate when and how fast it will converge.
