Will an object accelerate only while a force is acting on it?
  • Thread starter Thread starter Karan Punjabi
    Force
An object accelerates only while a net force is applied to it. For instance, when a baseball is thrown, it accelerates only during the time it is in contact with the thrower's hand. Once released, the ball moves at a constant speed unless acted upon by other forces like gravity or air resistance. The confusion often arises from the perception of continued motion after the force is removed. Ultimately, acceleration ceases once the force is no longer acting on the object.
Karan Punjabi
Guys I'm a student studying in FYJC sci. I like to get things in deep so i want to just ask a question... I don't know this question can be silly or not but i want to know that If on an object I acted a certain force for a time then the object will accelerate for that time i mean at that instant only for which force is acting or after it... I think this can be silly but please help me
An object will accelerate only while a nonzero net force is being applied to it. So, for example, imagine that you are throwing a baseball. While the ball is in contact with your hand, there are two forces on the ball: the one you are exerting in order to speed the ball up and also the force of gravity downward (the ball has a weight). Once the ball leaves your hand, you are not exerting a force on it anymore. Gravity will continue to act on the ball and air resistance will act as the ball flies through the air.
Short answer: An object only accelerates while a force is being applied.
I understand this but we interpret like the ball is accelerating after the throw but actually it accelerates till we throw it right?
Neither. It accelerates during the throw. The hand pushes the ball during the throw. Surely you're asking about something more subtle than this and we're missing it?
Let's ignore gravity and air resistance. We'll suppose you are throwing the ball in outer space. The ball will accelerate only while it is in contact with your hand. As soon as it leaves your hand, it will fly off in a straight line at a constant speed.
Yeah that's what i was confused about... It till will accelerate till the ball is in my hand. Thank you both to solve my problems
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
