Extraction/purification caffeine - help
  • Thread starter Thread starter soundlover
    Caffeine
The discussion revolves around the extraction of caffeine from tea leaves using dichloromethane (CH2Cl2) and sodium hydroxide (NaOH). After the liquid-liquid extraction, the organic phase containing caffeine is evaporated, and toluene is added for crystallization through slow evaporation. A question arises regarding the addition of petroleum ether to the crystals. It is clarified that petroleum ether serves as a transfer or rinse solvent, as caffeine is moderately soluble in it. Additionally, it is noted that crude caffeine is often dissolved in acetone to remove impurities before using petroleum ether.
soundlover
lo all, i´m having a small prob here
-extract the caffein of the tea leaves with CH2Cl2 + NaOH
- after the liquid-liquid extraction the organic phase (that contains the caffeine) was evaporated. then i joined some hot "toluen" (C6H5CH3) to the caffeine to occur a cristalization by slow evaporation of the solvent..
ok,i understand that but why the heck should i join some PETROLEUM ETHER to the cristals?
good lord,my english is painfull,sry
tks for any tip
Chemistry news on Phys.org
because ether is a good extraction solvent.
I believe it is used in this case as a transfer/rinse solvent, in which caffeine is moderately soluble. Usually the crude caffeine is dissolved in acetone, to remove the impurities and subsequently the former is used.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
