Understanding $\mathbb{K}$ and $\mathbb{R}^n$ - Get Your Answers Here
  • Thread starter Thread starter Hernaner28
    Doubt
The symbol $\mathbb{K}$ typically represents an arbitrary field, which should be explicitly defined in context. In contrast, $\mathbb{R}^n$ denotes n-dimensional real space, essentially the unique n-dimensional vector space over the real numbers. There is a distinction between referring to $\mathbb{R}^n$ simply as a set of ordered n-tuples of real numbers and considering it as a vector space with operations defined coordinate-wise. While many discussions assume the vector space structure, it's important to clarify the context to avoid confusion. Overall, understanding these symbols requires attention to their definitions and the structures implied in various mathematical contexts.
Hernaner28
Hi. What does that mean when we see:
$$\mathbb{K}$$ what set is that? definitely not the reals, integers, etc.
and
$$\mathbb{R}^n$$ Is that the reals or what?
Thanks!
Mathematics news on Phys.org
the blackboard K is often used to refer to an arbitrary field. If you encounter it somewhere it should be stated what is meant by it.
The blackboard R^n just means n-dimensional real space. So basically (up to linear isomorphism) the unique n-dimensional vector space over the real numbers.
Thank you!
A tiny disagreement. R^n is the set of order n-tuples of real numbers. It becomes a vector space only with the convention that "sum" and "scalar multiplication" are "coordinate wise". Yes, that is the "natural" convention but it separate from just "R^n".
You are right of course. Naturally my response was in terms of the vector space since this is the first definition I saw. You could also assume this and express that you are only talking strictly as the n-tuples of real numbers by mentioning you use the bare set underlying the vector space. I think in most literature the vector space (indeed also the natural topological, norm, inner product, Lie group and manifold (symplectic, smooth, Riemannian)) structure are assumed when used. A thing that might be stated explicitely is any algebra structure.
So immediately when I see that symbol these things I also assume, but it might pay to be a bit more reserved about this.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
