member 463737
Not sure if this is impossible, simply wondering if anti-sums are a thing, ie. (Anti)∑0.5n(n+1)=n.
Crack Dragon said:… do you know where I could do any reading up on summations and the like?
Crack Dragon said:Fixed n? I really am new to this, just in this format though if that's what you were wondering: http://www.wolframalpha.com/input/?i=Sum+f(n),+n=1+to+n, are you saying ∑0=1?
The way you're using the summation symbol is wrong crack dragon. You need to sum over a "dummy" variable such as "k" in the example below.Crack Dragon said:Fixed n? I really am new to this, just in this format though if that's what you were wondering: http://www.wolframalpha.com/input/?i=Sum+f(n),+n=1+to+n, are you saying ∑0=1?
What does Δ/Δn mean? I understand the operator d/dn, but have never seen similar notation using Δ.Jhenrique said:\\ \sum f(n)\Delta n=1 \\ \\ \frac{\Delta\;\;}{\Delta n} \sum f(n)\Delta n = \frac{\Delta1}{\Delta n} \\ \\ f(n) = \left\{\begin{matrix} 1 & n=0\\ 0 & n\neq 0\\ \end{matrix}\right.
Mark44 said:What does Δ/Δn mean? I understand the operator d/dn, but have never seen similar notation using Δ.
This (above) is what I've never seen before. Where does the k/2 on the right side come from?Jhenrique said:##\Delta f=f_1-f_0##
##\frac{\Delta f}{\Delta x}=\frac{f_1-f_0}{x_1-x_0}##
How in discrete calculus we not consider an infinitesimal interval but yes a discrete interval (unitary), so Δx=1, ie:
##\frac{\Delta f}{\Delta x}=\frac{f(x+\Delta x)-f(x)}{\Delta x}=\frac{f(x+1)-f(x)}{1}=f(x+1)-f(x)=\Delta f##
The same logic for summation:
##\sum f(x)\Delta x=\sum f(x)\cdot 1=\sum _{x}f(x)##
FTC for the discrete case:
##\sum_{x_0}^{x_1} f(x)\Delta x=\sum_{x=x_0}^{x_1}f(x)=F(x_1+1)-F(x_0)##
inverse relationships:
##\sum \frac{\Delta f}{\Delta x}(x)\Delta x=f(x)##
##\frac{\Delta}{\Delta x} \sum f(x)\Delta x = f(x)##
with infinitesimal limits...
##\int f(x)dx=\lim_{\Delta x \rightarrow 0} \sum f(x) \Delta x##
##\frac{df}{dx}=\lim_{\Delta x \rightarrow 0} \frac{\Delta f}{\Delta x}##
computing...
##\frac{d}{dx}\left (\frac{1}{2}kx^2 \right )=kx##
##\frac{\Delta}{\Delta x}\left (\frac{1}{2}kx^2 \right )=kx+\frac{1}{2}k##
Jhenrique said:##\sum f(x)\Delta x=\frac{1}{6}kx^3-\frac{1}{4}kx^2+\frac{1}{12}kx + C##
##\int f(x)dx=\frac{1}{6}kx^3 + C##
And you still have a Z transform that is the discrete analogue of Laplace transform. All this is the discrete calculus.
Mark44 said:This (above) is what I've never seen before. Where does the k/2 on the right side come from?
