Factorization and Simplifying.
The discussion focuses on simplifying the expression (x^3 + 3x^2 + 3x + 1)/(x^4 + x^3 + x + 1) through factorization. Participants highlight that x = -1 is a root for both the numerator and denominator, indicating that (x + 1) is a common factor. To proceed, one can factor the numerator further by expressing it as (x + 1)(x^2 + Mx + C) and determining the coefficients M and C through multiplication and coefficient comparison. The challenge lies in effectively applying these factorization techniques, particularly for higher exponents. The thread emphasizes the importance of recognizing roots and utilizing synthetic division or multiplication to simplify expressions.
AstrophysicsX
Use Factorization to simplify the given expression.
(x^3 + 3x^2 + 3x +1)/(x^4 + x^3 + x + 1)
I can't get to the first step. I forgot how to factor exponents higher than x^2.
Think about the binomial expansion of (a+b)3. Also you can check for roots using synthetic division. And remember a root x = r corresponds to a factor of x-r.
Theorem of the factor.
You can probably simplify the upper and the lower part, maybe even cancel out some stuff...
But how to do that is the problem.
If x=(-1) then the numerator and denominator are both 0. That means (x-(-1))=(x+1) is a common factor of the numerator and denominator. Now start factoring it out.
As others have pointed out, x=-1 is a "solution" to the numerator (equaling zero). So this tells you that (x+1) is a factor of the numerator. So what is the other factor?
If you don't like doing division, you can solve by doing multiplication. To start with, let's look at just the numerator:
x3 + 3x2 + 3x + 1 = (x+1)(x2 + Mx + C)
Multiply the right hand side to remove the brackets, and equate the coefficients on each side to determine the values of the unknowns M and C.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
