Falling object collision question
7 replies · 3K views
Stellar1
Hello,
I've been trying to figure out the physica behind a collision of two objects due to the force of gravity. Here's the situation as I'm picturing it:
A massive object A is falling due to gravity which impacts a stationary object B being held up by a structure. In this particular case, the structure is unable to support the impact force of object A and fails, causing the now combined object AB to continue falling.
My difficulty is in picturing how the forces interact during the collision. Object A is falling with a force of F=MaG, which is then applied to Object B. At this instant, object B begins its acceleration... Would a force F be applied, during the collision, to Object A in the opposite direction due to Newtons 3rd law?
Hello Stellar1! :smile:
That isn't how it works.
Mag is the force on A (from the Earth).
To find the force on A from B, you find the acceleration of A during the collision, subtract that from g, and multiply by Ma.
The force from A on B is of course the same (Newton's third law).
(that's if you analyse it instantaneously …
the more sensible way would be to use impulse, rather than instantaneous force)
If object A is on object B, the it is applying the force MaG onto it, no?
The only way I can reconcile this in my head is if I take compressibility into account. That allows for object B to accelerate and object A to decelerate until a common speed is achieved and gravity accelerates the combined object.
no :confused:
the force from A on B (or vice versa) depends on a lot of things
Let me rewrite this now that I'm not doing 3 things at once and able to think about this with minimal distractions:
I know that A will be falling with a force of Fa=mag onto object B, which can only support a force of, say, Fs. The length of time object A is under this acceleration will allow us to determine the velocity of object B at the instant just prior to collision, which we will call vi
Now, assuming object B is incompressible and, since we assume Fa>Fs, its perfectly consistent to assume that the force during the collision will break the supports and object B will now accelerate from rest under the collision force of object A, as well as gravity.
Since we assume that object B is not very compressible, wouldn't this mean that object A has to essentially come to rest as well, so that object B (now joined to A) will both accelerate from rest (since B is starting from an initially stationary position)? This would then imply that the velocity at the instant just after collision is 0, correct? The force exerted by A on B (and by B on A) would then equal F=mavi/t + mag, where t is the duration of the collision.
Is there any way to determine how long this collision would take?
Stellar1 said:
I know that A will be falling with a force of Fa=mag onto object B …
No, that's completely wrong.
Before A hits B, it has an acceleration of g downward, and there is a force on A (from the Earth) of Mag.
A does not exert a force of Mag on anything (except of course the Earth).
When A hits B, A will slow down a lot, and will also change shape slightly. B will also change shape slightly, and will start accelerating.
You find the force by finding the acceleration first (on either A or B), and multiplying that by the mass.
You find the acceleration by using Newton's second law, which is about momentum, and also using your knowledge of the elasticity of A and B.
Ahh, yeah. That's what I meant. Falling onto =>Falling towards with a force of F=mag which accelerates it to a certain velocity prior to colliding with B.
