Falling time for a free falling object through large distances
8 replies · 2K views · last reply
Vicara
Well, first of all i want to apologize about my english skills hahaha
I have been trying to calculate a time formula for free falling object through large distances (or weak gravitational fields) and my results don´t have much sense (I test my results in a quite realistic game called Algodoo)
What I have calculated is
g(r) = G⋅(M/r2) and as g = dv/dt = dv/dr ⋅ dr/dv = dv/dr ⋅ v
we got
∫v⋅dv = ∫G⋅M/r2 = 0.5⋅v2 = G⋅M⋅(-1/r)
v(r) = √(2⋅G⋅M⋅(-1/r)) = dr/dt now we integrate both sides ∫dt = ∫1/[ √(2⋅G⋅M⋅(-1/r) ] ⋅dr
and finally
t = t0 + (2/3)⋅√(r3/-2⋅G⋅M)
Please tell me what is wrong or if what i´m doing makes sense
Thanks!
First, sign: a = -GM/r2: acceleration is towards the mass.
Second, you need a definite integral: ∫-G⋅M/r2 = GM(1/r - 1/r0)
Well, I have done that and now i have something that I don't know how to integrate (I´m actually not very good at calculus)
https://ibb.co/dhztfv
Sorry for the photo :/
There are a few old threads about this. Note that these threads are considering the time it takes for two objects to collide (both objects accelerate towards each other), but it seems they have similar intermediate formula for velocity, M for the one object case, (m1+m2) for the two object case. For the 2 object case, if m1 >> m2, then the sum (m1+m2) ~= m1, so let M = m1. Some of these consider point objects others consider objects with non-zero radius.
See post #11 for a Kepler's law approach and post #19 for the approach used here:
Non constant accelleration equation(s)
Using a different substitution here, and also allowing for non-zero radius objects:
Rectilinear motion of two attracting masses
See post #66, #68, and #73 for examples of both substitutions:
time-of-a-falling-object-when-the-force-of-gravity-isnt-constant
Oh, thanks! :bow:
Now I will spend a few hours trying to understand that hahaha but I´m sure that it will be worth :D
Hi again
There is something that I don't understand in the solution of the problem (the part after "using arildno's method") which integrating method did you use to solve sqrt (r/r0-r) dr?
I guess you have the integral
$$I=\int \mathrm{d} r \sqrt{\frac{r}{r_0-r}}.$$
Let's try the substitution
$$r=r_0 \cos^2 u.$$
Then you have
$$\mathrm{d} r= -2r_0 \sin u \cos u$$
and thus
$$I=-2r_0 \int \mathrm{d}u \cos^2 u.$$
Now we have
$$\cos(2u)=\cos^2 u - \sin^2 u=2 \cos^2 u-1 \; \Rightarrow \; \cos^2 u=\frac{1+\cos(2u)}{2}$$
and thus
$$I=-r_0 \left [u+\frac{1}{2}\sin(2 u) \right]=-r_0 (u+\sin u \cos u)=-r_0 \left [\arccos \left (\sqrt{r/r_0} \right)+\sqrt{(r/r_0-r^2/r_0^2)} \right].$$
$$r=r_0 \cos^2 u.$$
Then you have
and thus
Now we have
and thus
ohhhh, okey, now i got it hahaha
Thanks to all ^^
The prior threads showed two different substitutions. The arildno substitution is:
$$u = \sqrt{\frac{r}{r_0-r}}$$
That post then solves for r and then takes dr to end up with:
$$dr = \frac{2 r_0 u \ du}{(1 + u^2)^2}$$
This results in :
$$\sqrt{\frac{r}{r_0-r}}\ dr = \frac{2 r_0 u^2 \ du}{(1 + u^2)^2}$$
